Power Loading
Old 07-23-2013 | 11:17 AM
  #41
Had to give mine a little throttle to load on the trailer just right last year at the State Park ramp @ LOTO. It was a combination of me not wanting to hold up the ramp as it was busy and a very steep angle. But usually I just crank it up the last foot or so with the winch. No reason to get rammy
TylerBurich is offline
Old 07-23-2013 | 11:20 AM
  #42
Sydwayz's Avatar
Forum Regulator
Originally Posted by CraneHillFast
This just sounds like a classic idiot loading his boat. There is never a reason to use that much throttle.
The ramp I use every single weekend is power loaded and unloaded 100% of the time by 100% of the boats. I didn't even know it was illegal in a few states until i read about it in Boat US magazine i think last month. Like I said the ramp I use every weekend you do not have the option to rope on or off unless you want to be shoulder high in water. If you place your trailer properly you shouldn't even have to use throttles. I wedge my nose idling on and wench the rest. 30 seconds tops from my nose hitting my trailer to my boat being out of the water if I have my buddy helping me. If I'm by myself, two minutes. Granted I only have a 27 ft boat but it's not all that different if you work with your trailer placement.
That's not powerloading. That's idling onto the trailer, and winching it the rest of the way home.
Originally Posted by sommerfliesby
I still have to "power load" the AT....but its a matter of idling up and getting centered on the bunks, then a slight bump to get the bow into the V. If I drop it super deep, the V-block hits my paint and causes damage. Guess how I know....
I don't remember doing this when we retrieved your boat when I was in town. It all depends on the ramp, and you are the one there; not me. But my regular routine with any of the 37's is drive onto and land the boat on the trailer (just like you would gently beach a boat) and winch it the rest of the way up. The only time I did not do this was loading Clark's boat once in Marathon (Key) in the middle of the night, pitch black, on a crappy ramp, at low tide, with a current, with one drive and no power steering. I powerloaded that S.O.B. at 4500 RPM to get over the trailer as we had only inches of water over the bunks, and we wanted to get to Key West before the bars closed. We made it.
Sydwayz is offline
Old 07-23-2013 | 12:15 PM
  #43
sommerfliesby's Avatar
I don't remember doing this when we retrieved your boat when I was in town. It all depends on the ramp, and you are the one there; not me. But my regular routine with any of the 37's is drive onto and land the boat on the trailer (just like you would gently beach a boat) and winch it the rest of the way up. The only time I did not do this was loading Clark's boat once in Marathon (Key) in the middle of the night, pitch black, on a crappy ramp, at low tide, with a current, with one drive and no power steering. I powerloaded that S.O.B. at 4500 RPM to get over the trailer as we had only inches of water over the bunks, and we wanted to get to Key West before the bars closed. We made it. [/QUOTE]
Yeah...that's what we did when you were there. I've tried cranking it all the way up, but it won't go. Might have something to do with the fact that I had to have the winch-stand lowered as I only had like 2 inches between the winch and the bow of the boat when it was new. That changed the angle of attack.
I am still learning, however. Did the damage at PB2 at Loto....trailer was too far in, so when I drove on and hit the bow stop, the carpeted area was in contact with the red paint. When I pulled out, it rubbed hard and smeared the paint...actually totally rubbed it off in a 1/2" x 2" section on each side of the bow.
sommerfliesby is offline
Old 07-23-2013 | 12:23 PM
  #44
Originally Posted by Payton
Hey you guys that powerload, please check the rules if you go to a different ramp. I am only a rope-boater I guess because the powerloaders dig holes at our ramps and make the bottom uneven for my trailer. 2 out of 3 of the closest ramps are on a ditch or creek with current. We don't like holes at the end of the concrete.
While I agree that heavy propwash causes serious damage, those of us that idle onto our trailers may be "loading under power" but that's not causing the errosion issues. Do you shut your boat off 300' from the dock and swim it in so your wash doesn't disturb the bottom durring docking? Do you dock your boat with no reverse, or countering props? These actions would create the same if not more errision at the ramp than idling onto the bunks. I'm not disagreeing with anyone, just clarifying for those that may be confused.
Idling on the trailer is NOT power loading in my opinion, and anyone that thinks this causes anymore damage than just simply operating a boat in shallow water near a ramp is clueless.
RT930turbo is offline
Old 07-23-2013 | 12:31 PM
  #45
Sydwayz's Avatar
Forum Regulator
That is the only thing I do not like about Ron's trailers. I hate that carpeted block up there.
If it were me...
I'd call Loadmaster Trailers of Ohio have have them send you this bow catcher:
http://www.loadmastertrailerco.com/options2/
[ATTACH=CONFIG]504936[/ATTACH]
You can call Myco and they will also send you the same, but it's fixed--not adjustable. IMHO, the Loadmaster version is better than Myco even as the Myco has the rubber/silicone blocks sitting in a small cradle with steel sides. The outer sides can damage the hull if you come in really crossed up. It happened to another Myco owner I know.
Sydwayz is offline
Old 07-23-2013 | 12:34 PM
  #46
I have never powerloaded at the dock. I don't see how that saves any more time that loading your boat on the trailer by the strap. I can and have loaded mine on within a few minutes. As a matter of fact I can load it faster by cranking the strap faster than most of the D-Bags at our local ramps driving the boat up on the trailer...... And I never get wet either... Usually have my shoes on. Simply back trailer in ramp close enough to the dock, take a large step from dock to trailer, walk trailer, hook strap and crank.
low_psi is offline
Old 07-23-2013 | 12:37 PM
  #47
97FASTech's Avatar
Veteran: Army
Originally Posted by RT930turbo
Same here, however, there is a difference between sliding nicely up the bunks at idle speed and using 3/4 throttle to climb up a half-submerged trailer. I almost always boat alone, and in following proper (maybe local?) ramp etiquette I tie the boat to the courtesy dock as to not hold up the ramp. I fetch my trailer then jump in the boat and slide the boat right up to the bow stop, hook and I'm done. This might be considered "power loading" but it's hands down the quickest easiest way to load the boat. I rarely need any throttle and if i do, it's 1200 RPM MAX for a split second.
I also do the exact same, except I end up winching mine twice. First time with forward bunks quite a bit out the water to center (catch) boat, attach strap, winch a bit. Then move trailer a little bit more in the water, winch rest of the way up. This works best since the wind blows most of the time, and the idiots that don't know what no wake means. I never get my feet wet, as I precariously walk the tongue from the bed of the truck. lol I also launch and retrieve by myself faster than 95% of jet skiers and families.
97FASTech is offline
Old 07-23-2013 | 12:58 PM
  #48
Loadmaster will sell just the rubber blocks if you want to modify your existing bow stop to the rubber block stoppers.
BGIII is offline
Old 07-23-2013 | 01:21 PM
  #49
Payton's Avatar
Charter Member #927
The ramp at Portage does suck. Its a bad angle. If I pul up to my bow stop or winch up to it, when I pull up the ramp my bow is 2" away. Doane"s is a good angle but we get holes in the ditch there. That's why I have a slip now and only load 2-3 times a year.
Payton is offline
Old 07-23-2013 | 01:29 PM
  #50
Knot 4 Me's Avatar
Our main ramp at the marina is 5 lanes wide so there is no walking your boat onto the trailer unless you get one end or the other. If you are in the middle 3 lanes you have to run the boat up onto the trailer. I would say at this ramp, regardless of what lane you get, 95% of the boaters powerload. .
Knot 4 Me is offline
