anyone ever build a 41 apache with diesels and arnesons? >
Old 07-28-2013 | 09:31 PM
Over on powerboatlistings.com there is a 41 Cig listed out of N. Miami rigged with Isatto Franschini Diesel Motors & Arneson Drives....
I know nothing about it but put it out there if anyone on here can add anything from this cig's performance to Ratman's original inquirey???/
speicher lane is offline
Old 07-28-2013 | 09:33 PM
Coanracing.com. For trans. Call saber for a 41 they have a 41 cc on floor that could work. Or get a hull new
jdos is offline
Old 07-28-2013 | 11:12 PM
ratman's Avatar
i saw that boat, i would want inline 6 cylinder diesels, i never heard of those engines and getting parts for them in colombia...forget it... cummins is world wide...
ratman is offline
Old 07-29-2013 | 12:15 AM
Rik's Avatar
Rik
arneson-industries.com
Price will probably decide the hull choice for you, but the 41' Apache or the newer 42' Chief hull will work. Definitely use a stock Cummins QSB6.7 550 hp engine and then it's easy from there.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 07-29-2013 | 06:44 AM
Quinlan's Avatar
There is an old Cig w diesels on Grand Lake in OK Listed at Shangri-La web site I believe.
Quinlan is offline
Old 07-29-2013 | 06:50 AM
I wasn't pushing it by any stretch - it's just a 41 that someone actually converted in the same manner that you were thinking. I put it out there in case someone on here actually had seen the boat and knew if it was actually successful.
I have heard of Isatto Franschini Diesels but I think they are the type of engine that becomes an offshore anchor at the first sign of trouble....I could be wrong but as you mentioned - Cummins is worldwide
Old 07-29-2013 | 06:54 AM
That was a factory produced Cig was it not??? I think there is a thread on here about a 41getting a refresh
Old 07-29-2013 | 08:29 AM
There was a few 40' cig 'attacks' that were rigged with 3208 cat diesels and arnesons -- there is one close to me. not real fast - 60mph -- but seems to be good in the rough since it's heavy. I saw one for salew on boattrader not long ago also. I would toss the cats in favour of a set of cummins.
If you were to rig a 41 apache i think you would want to slide the engines ahead a little in order to get the COG proper as the diesels --especially cummins 8.3's will weigh up compared to BBC's....
delsol is offline
Old 07-29-2013 | 09:42 AM
cookee's Avatar
British member!
I would second the marine diesel approach rather than marinising a truck motor - it would end up more expensive and less reliable. See Pat Weismann about gearboxes, I believe he has done some stuff with Rik in the past.
We would be interested in a project like that but we're the wrong side of the pond.
Full stagger on a slim hull and it will be a fast ocean cruiser.
Cookee
If it's too loud you're too old!
BananaShark Racing
British Champions 2005!
cookee is offline
Old 07-29-2013 | 09:49 AM
I would run them side by side and use the offset from the gear boxes to keep the drives together, no different than the Buzzi boats of years past. Put more fuel foward or water ballast if you need balance?
HabanaJoe is offline
