Props and rpm
Old 08-06-2002 | 09:27 AM
RUSSSR1's Avatar
Mopower
At 3000-3300 I can only get 35-37 mph. I think first thing to do is send my props to the shop and make sure I know that they are were they should be. Could you loose 10 mph if the leading edges had some dings.
Russ
RUSSSR1 is offline
Old 08-06-2002 | 09:33 AM
RUSSSR1's Avatar
Del Sol
Thats a lot more boat than what I'm pushing. I don't spin up the 25p at all. I can give the go anytime from idle on up with no spin.
posibly you should look for more bite with a four blade.
Russ
RUSSSR1 is offline
Old 08-06-2002 | 01:28 PM
mopower's Avatar
Toxic FORMULA
Russ , Interestingly enough I will spin my 25"Mirages getting up on plane unless I drop the drives all the way down Perhaps I have a slightly higher X dimension. This could account for some of the difference in speed. You would need some MAJOR dings in the props for a 10 mph difference
mopower is offline
dogghouse
Baja
2
11-07-2006 11:07 AM
superboat1989
Prop Talk
3
02-17-2006 12:05 PM
Summer Heat
Fountain
4
03-10-2005 03:51 PM
RUSSSR1
08-06-2002 04:44 PM
John B
0
06-16-2002 06:15 PM
