How do u get a boat off the trailer in the shop? >
Old 09-22-2013 | 11:15 AM
ratman's Avatar
skyhook?
ratman is offline
Old 09-22-2013 | 11:26 AM
Originally Posted by nova26
What's the best way, or ways? So the trailer could be painted and the boat not left in the water.
Sounds like a hastle and there is potential for damaging the boat. Know anyone with an empty lift? Dump the boat in the water a buy them a case of beer for the use of their lift
JRider is offline
Old 09-22-2013 | 01:30 PM
My boat isn't that big in perspective (21' approx 1000lb dry), but I tied the back of mine to a large palm tree in my front yard, unhitched the front then slowly rove the trailer out from underneath. I threw a few old tyres under the back and front as I went.
Getting back on is a little trickier but I basically hooked up the winch strap, spray carpet on skids with mr sheen, then winch and back the trailer back under slowly at same time.
Kurt Hamilton is offline
Old 09-22-2013 | 01:44 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do a search, there are several posts on this in the past.
Sydwayz is offline
Old 09-22-2013 | 02:03 PM
You can also go to a marina and they will pick it off and store it for you. Extra money but if you don't have the skills beatins tearing up boat
Crude Intentions is offline
Old 09-22-2013 | 03:08 PM
FREEZE FRAME VIDEO's Avatar
freezeframevideo.net
Active Streak: 30 Days
Commercial Members
fork lift and a frame for stern for the freeze frame boat
FREEZE FRAME VIDEO is offline
Old 09-22-2013 | 04:58 PM
Why not find a well and just put the boat in the water ?
Interceptor is offline
Old 09-22-2013 | 05:12 PM
Go to a marina and have them set it in dry stack for a couple weeks. Cost is probably less than what your time is worth to get it off and on in your garage.
hotjava66 is offline
Old 09-22-2013 | 06:20 PM
Roller trailer? Put a snatch block on the fwd crossmember, run the winch cable through the pulley & back up to the bow eye. Winch the damn thing off quicker than running to the marina. When you have weight on the stern blocks, start moving the trailer, not the boat.
Its not a major deal....
High Cetane is offline
Old 09-22-2013 | 07:58 PM
Yard arm that I borrowed but man it was nerve racking the first time!!!
ICDEDPPL is offline
