Boat wiring
Old 11-11-2013 | 06:48 AM
good info here also
http://www.marinco.com/page/wire-tech-data
pstorti is offline
Old 11-11-2013 | 06:53 AM
Mbam's Avatar
Offshoreonly Advertiser
The stock mercury trim harness has a pair of bullet connectors in the back to connect to the trim limit. Then it has an additional wire for the trailer switch. Are you going to re-use the stock harness?
Mbam is offline
Old 11-11-2013 | 08:22 AM
Im going to order one of the replacement main harnesses, a replacement trim harnes and then run the rest new.
phragle is offline
Old 11-11-2013 | 11:14 AM
Mbam's Avatar
Sounds like a plan
Mbam is offline
Old 11-11-2013 | 05:53 PM
Audiofn's Avatar
Charter Member #232
There are a few ways you can wire the trim limit switch. If bet if you google "mercury wire harness diagram" you will get plenty of them. Another thing to think about is your battery and what accessories you may want to be powered at all times. Thinks like trim is nice to have hooked up directly to the battery on outboard because I can just reach up and trim the motor from the ground. The bilge pumps of course NEED to be on constant power. If you are calculating what gauge wire you need to run, remember with DC it is the entire length of the run up and back. So if you have a 2 conductor wire that is 10 feet then you should calculate your power loss at 20 feet.
I have attached the Coast Guard chart for wire sizing. I find it to be a little overkill but it is a good reference.
Jon
[ATTACH=CONFIG]512195[/ATTACH]
Put your best foot forward!
Audiofn is offline
