Yes I would replace the 6x9 with 6.5". I would have angled the speakers in pocket back and up not forward and up. Put a set infront of the bolsters. That should still get you pretty good coverage in the cockpit. A couple of subs in the bench and you are set. Best if you do enclosed boxes, but free air will work.
Make sure you have the right power. For your 6.5" best to have 125% of the rms power for the speakers. So if they want 100 watts each get an amp with 125 watts rms output. For the subs go at least 150%. Also running three sets of 6.5" you will probably have to go with a 4 channel amp. Run two sets of speakers off one set of channels and just one off the other set. Not many of todays switching digital amps like 1 ohm loads. But this will give you the ability to add a set of speakers in the cabin or something later.. |
Originally Posted by FIXX
(Post 4051115)
whats up with the 3 rd pic? i would stick with a 4 ohme sub,,2 ohm over amps and turn up way too fast..if you like loud and muddy base then you may like it..me personally i like 8 ohm with alot of power,,i prefer a 15'' ev speaker with a cloth rolled edge which makes the base snappy..their are all differant ways to wire the speakers,if you need information call me and ill walk you through it..i worked for a rockford distributor in my early 20's and did all their installs including some popular people's vehicle's
Here is a thread on the setup in my boat.
http://www.speedwake.com/forums/show...+boom+boom+pow I'm not to far from you so if you need any help or need to ask any questions give me a shout. |
i choose the amps that i did because they are the ones designed by wetsounds to work with the speakers i am gettin. i agree %100 with the over power of the speakers,but according to the company this is the best set up.
Originally Posted by Nightlife1970
(Post 4051222)
Originally Posted by pstorti
(Post 4051411)
I don't understand this advice, why is this a good way to set it up? Wouldn't a 6 channel amp be better? Seems like one side of this 4 channel amp will be working very hard and the other not hard enough. And also if you have the space and $$ won't the sound be cleaner running amps at 4 ohms vs putting lots of speakers on each channel to get the ohms down and the power (and distortion?) up?
(Post 4051629)
Yes a 6 channel would be great, but not as easy to find. A 2ohm load is not working hard for new amps that's what they are designed for. You won't hear the difference from .5% distortion to 5% in a boat. And distortion is only present if you run the amp to that point. It's all a balance of power, space, and cost. I run my whole system at 1.3ohm. There is no distortion in it, until I drink to much beer :)
I like beer!!! |
Me too!
| All times are GMT -5. The time now is 11:23 PM. |
