Shop vac use #101
Old 02-01-2014 | 01:46 PM
Default Shop vac use #101
With all this talk of busted blocks and sub-zero weather, I could not stand it any longer. I opened the hatch and rechecked the coolant in the closed cooling system. Then I took some lines loose and using the shop vac, started sucking all the pink stuff out of the system.. Pulled from about every point I could think of. Then, I left a light in the bildge just in case. I feel better now.....
David H is offline
Old 02-01-2014 | 02:39 PM
bluellama's Avatar
I was thinking maybe you stuck the shop vac in your bilge, and ran a long insulated hose to the garage to suck warm air into the boat ....
Your idea makes more sense...
bluellama is offline
Old 02-01-2014 | 11:53 PM
Kinda like locking the barn after the horse is gone. What is done is done and a few of us are in for a surprise next spring.
All these mild winters have set many of us up for a disapointment.
NautiNuff is offline
Old 02-02-2014 | 01:17 AM
If you put the hose in the exhaust side they work great for inflating water toys, small leaf blower works good too (-:
n20michael is offline
Old 02-02-2014 | 08:57 AM
Pink RV antifreeze does not expand when it freezes.
Crossett is offline
Old 02-02-2014 | 11:23 AM
neither does air.
drain the damn block, sheesh.
Cole2534 is offline
Old 02-02-2014 | 12:45 PM
I feel better anyway at this point. More cold a$$ weather headed this way. Good point Cole2534.... no worries with only air in the bolck.....
David H is offline
Old 02-02-2014 | 06:31 PM
First year year mine has been in a heated building. Even with that said, I still winterized the blocks as I do every year. No one has ever regretted taking to many precautions. Too much at risk!
donzi33zx is offline
