Marine Generators
If it's permanent install for you, my bud has an 4.0 Onan on his offshore fishing boat with a $hitload of hours that never gave him a problem.
I've been told steer clear of Kohlers, don't ask me why, LOL!!! as I don't know
Good luck in your search.
See ya,
Kelly
Kohler's leak water from raw water pump back into the generator portion. Then you have an expensive repair bill. Engines use are Kawasaki and have had a history of being finicky.
If you are interested in a Honda, pm me as I have helped out many here on oso.
A 3000kw Honda is far from one you lug around and strap to your platform. A 2000 may work, but depending on the size of your AC, it may not work. My 2000 will run my 9000btu AC. A buddy has a 12000btu AC and he has to run 2 2000's.
Most of the cruisers around me run either Westerbeke or Kohlers, if you are looking for a perm. install
Then you will need to go with either a Westerbeke or Kohler. I currently have a Westerbeke in my 442. Kohler parts I think are more reasonably priced and readily available. Westerbeke's seem to be more reliable but harder to get parts and they are usually more expensive. I have some friends that gave up their hunt on Westerbeke parts recently and had to replace the complete unit.
No- You should go with the Westerbrooke. Better unit overall. But make sure you have a CO detector installed too. I would contact Outerlimits and see what they do for install. A 39 is a smaller boat for a gen-set. They need room.
Wannabe
Wannabe
put something nice in your fine boat, dont install a piece of crap genset. look at a notherm lights, with sound shields, they run for ever...top of the line equipment... rm
http://www.lugger.com/
here is a 4.5 kw their smallest http://www.lugger.com/marine/M673LD3.html
