Need Opinions
Old 02-20-2014 | 12:30 PM
Originally Posted by baditude
Stereo was already installed when I bought the boat, and to be honest I have never really looked very close at it. I was told that the new stereo was done at the same time as the interior redo.
That makes sense, they probably wrapped around the holes then. Unfortunately I don't have that luxury.
ealesh33 is offline
Old 02-20-2014 | 12:33 PM
Here is the driver's side.
[IMG][/IMG]
Ok, yea i was looking at there or behind the controls right above the seat arm in that spot. I wanted livorsi controls, I thought and thought about it and finally decided that money would serve better use in another place and to redo my current ones. I didn't pick up ones for the front up high, just got 6X9's to replace the ones in the boxes under the dash. I have the ability to add another pair of speakers, and if I do more then likely it will be 6.5's upfront like yours
ealesh33 is offline
Old 02-20-2014 | 12:36 PM
Originally Posted by ealesh33
Here is the dash with gauges
That's pretty slick. Where'd you get the carbon done and how much was it?
Crossett is offline
Old 02-20-2014 | 12:39 PM
Yes, this is actually the pic in the add the guy posted that I purchased it from. I got carried away, and did alot of stuff that honestly could have been left alone. But gotta make it yours and nicer I guess lol. I replaced the system cause it had some mismatching stuff, and had a 4 8" sub set up, and I went to a 2 10" set up with bigger mid/highs in the back and added 6.5's up high in the gunnels. Also got better more efficient running amps to push the system. The whole carpet scenario is only brought on cause I have to find a solution to re cover the back seat, and the more I look at it I am back and forth. Am more leaning towards just re doing all the carpet to freshen it up, and bring more focus to the blue's in the boat. Right now its alot of blue
Should of went with 4 10's lol They fit fine!
baditude is offline
Old 02-20-2014 | 12:41 PM
Oh and there is room to add them lol
ealesh33 is offline
Old 02-20-2014 | 12:44 PM
Were did you mount your amps?
baditude is offline
Old 02-20-2014 | 12:45 PM
Its hydro dipped, and I had it done by a local graphic vinyl/hydro dipping business called Hi-Def Customs. It was $150 to have the dash, switch panel, fuse panel, drive trim panel, and trim tab panel done. It has automotive grade clear over top, so it is durable and can be cleaned. Then I picked up all new labeled switch covers from New Wire Marine so all of my switches were labeled on the cover since the hydro dip would cover them on the panels.
ealesh33 is offline
Old 02-20-2014 | 12:47 PM
The system that was in the boat when I purchased it, the amps are mounted right on the other side of the dash in the cuddy on the bulkhead wall. I am going to put the new ones in the same spot.
ealesh33 is offline
Old 02-20-2014 | 01:17 PM
You just dipped the factory piece? How'd you fill the holes so you could drill new ones for the 2 extra gauges?
Crossett is offline
Old 02-20-2014 | 01:27 PM
I made a new dash panel at work, I made it all by hand. Here is a photo of the old dash and the new .
Here are all of the panels after being dipped and cleared
ealesh33 is offline
