Need Opinions
Old 02-20-2014 | 07:00 PM
  #31
Originally Posted by ealesh33
Yea I spoke to the guy that has the shop where my boat is, and he said gel coating wouldn't be the best option. I did not consider that, that could be a simple fix right? You think that could glue on, or would have to be screwed on? Here is the seat, the front panel, and the actual seat panel with the hole in it I just did. I did the seat portion because the hole was cut position further back, and the seat is suppose to be hinged from the front part of the seat. Well the hinges are no longer there, and when you would step on the back seat there wasn't enough wood towards the back to support the seat so it would slide into the hole and the seat would really flex, so I just positioned the hole more forward so there is more of overlap in the back to support the seat cushion. Here is a photo of the seat all finished with the new panels.
I would think some white, non transparent 1/4" lexan or acrylic glued on with 5200 would work just fine and never move.
Since your seat bottom just sits on there(just like my 32 AT), you can screw a piece of 2" x 2", about 18" long, to the underside bottom of the seat cushion wood.
The 2x2 sits down in the hole right at the front edge and will keep the seat bottom from sliding forward.
Griff is offline
Old 02-20-2014 | 08:08 PM
  #32
Thats exactly what I was going to do before I decided to do the new stereo system, and had to redo the panel for the speakers. If the extra 1.5 inches of wood in the back from the new piece doesn't work I will do that. I may do it anyway. I am going to see what I can find for white acrylic or lexan
ealesh33 is offline
Old 02-20-2014 | 08:11 PM
  #33
The scarab I had came from the factory with formica along the front of the seat. It seemed to hold up fine. It comes in shiny white, is cheap, and installs easily with contact cement and a router.
Katanna is offline
Old 02-20-2014 | 08:23 PM
  #34
Awesome man, thanks. So no screws or anything required, just contact cement or 5200?
Formica as in countertop material?
ealesh33 is offline
Old 02-20-2014 | 08:31 PM
  #35
What about upholstering the panel, or upholstering a thin piece of plywood and mounting it to the front of the seat. You can just get a white piece of vinyl and some thin foam and glue/staple it in place. If you do the thin plywood, you can either glue or screw it to the seat front.
Eddie
Young Performance is offline
Old 02-20-2014 | 08:37 PM
  #36
Yes as in countertop Home depo available. Have to install with contact cement. Roughcut, brush glue on back of formica and front of seat base, let dry to the touch and apply formica. It will stick instantly. You will be able to trim all the edges and the speaker holes in about two minutes with a router.
Katanna is offline
Old 02-20-2014 | 08:47 PM
  #37
Eddie
Whats up Eddie, my name is Eddie as well lol. That was the original plan and already have the vinyl that matches my other white vinyl as I have to wrap the rest of the seat base. Only the front where the speakers are was carpet the rest was vinyl. I kinda veered away from that idea due to where it is and thinking that the vinyl would get ripped, scuffed, etc...Was thinking I needed something more durable there. You don't think so?
ealesh33 is offline
Old 02-20-2014 | 08:55 PM
  #38
I don't think so. The vinyl is VERY durable, not to mention, it's really cheap to replace if needed. There are quite a few boats out there with the front of the seat base upholstered. I've made some panels in the past to do just what you want to do. We used a piece of Luan plywood, cut out the speaker holes, upholstered it, and mounted it to the front of the seat. The speakers are mounted to the seat base and just poke through the upholstered panel.
Awesome name by the way
Eddie
Old 02-20-2014 | 09:09 PM
  #39
Eddie
Is there a particular reason why you use a separate piece of wood wrapped and not just wrap the actual front?
ealesh33 is offline
Old 02-20-2014 | 10:05 PM
  #40
Randy Nielsen's Avatar
[ATTACH=CONFIG]519029[/ATTACH][ATTACH=CONFIG]519030[/ATTACH][ATTACH=CONFIG]519031[/ATTACH]I am redoing the interior in my Eliminator & built a new pedestal for the rear seat. The original had 2 8" woofers, whereas the new one houses 4 10" subs. I decided to cover it in the same material as the rest of the interior. I think it looks good & took about an hour to cover. Randy
Attached Thumbnails Need Opinions-dark.jpg   Need Opinions-lights.jpg   Need Opinions-back-seat.jpg
Randy Nielsen is offline
