Need bmw mechanic
Old 03-19-2014 | 11:13 AM
moparjet's Avatar
Originally Posted by TURBO JET
What year car do you have and motor?
what he said
moparjet is offline
Old 03-19-2014 | 05:38 PM
JIMKID Motorsports's Avatar
2007 328 xi and no I did not set the motor before pulling it off and did hear a springing noise when removing the motor
JIMKID Motorsports is offline
Old 03-20-2014 | 06:55 AM
Bad Ass TA WS6's Avatar
Wind the 4mm allen @ the back of the valvetronic motor clockwise by hand until it stops. Remove the motor and check the base flange and ensure it is flat/straight. Sometimes it helps to wind the motor counterclockwise slightly to get it out. Same goes when you reinstall, wind clockwise and make sure it is fully seated/lined up with the holes, then install the 3 bolts. Cycle the key (start/stop) and listen for the valvetronic to do its full sweep.
No misfires or faults correct?
Bad Ass TA WS6 is offline
Old 03-20-2014 | 07:07 AM
Also ensure the valve cover gasket hasn't fallen out of its groove/oxygen sensor wiring isn't pinched at the rear of the cover. Use a mirror and check around the whole VC
Old 03-20-2014 | 07:42 AM
i live down the street from you, im in Walled Lake, been working for bmw for 10 years. I can swing by. I also believe we meet at the Kielian bday party.
The 30 ft Skater with LS7, not too many out there.
prostock3 is offline
Old 03-20-2014 | 11:03 AM
moparjet's Avatar
also check the crank vent hose at back of valve cover. make sure its secure and not cracked
moparjet is offline
