A little winter upgrade project
Possibly you have me/ my boat confused with....
http://www.offshoreonly.com/forums/g...e-1000-hp.html
spent the day cutting and drilling holes for the chartplotter, gps antenna, trim sticks, azimuth compass etc. and did a little more derigging. SAturday I hope to finish the holes, get mesurements for the battery shelf. sunday I will make the console and shelf then its time to start putting the boat back together.
Got the console built today.... just need to add the cupholders and then lots of polyurethane and sanding
[ATTACH=CONFIG]520820[/ATTACH]
[ATTACH=CONFIG]520821[/ATTACH]
[ATTACH=CONFIG]520822[/ATTACH]
I used it to pop the old floor loose.
Not much progress to report right now. I have been finishing the console. sanded it, added a coat of sanding sealer, sanded, another coat of sanding sealer sanded polyurethan, sanded, more poly.. more of the same tomorrow. Since the console is 3/4 marine ply I want to make sure its sealed good. When checking the fit I noticed that the factory cut job on the bottom of the dash was more than likely done by a drunken trunk monkey. So I have been straightening that, Made a template for the battery shelf while the poly was drying and more parts and rigging supplies show up daily., I think the mailman is beginning to hate me, every day 3 or 4 packages....
