Low of 27 Tonight, Should I do anything??? >
Old 04-15-2014 | 02:42 PM
I honestly think you'll be fine. 1 night below freezing and then a sunny day tomorrow probably won't cause any freezing issues. If it were convenient, do the light bulb for pc. of mind, but since it's not, don't worry about it.
MonkeySea2 is offline
Old 04-15-2014 | 02:51 PM
Originally Posted by ealesh33
so the low is suppose to be 27 tonight, and it will be 32 or under for about 6 hours, should i be worried about the boat at all? I am thinking no, but wanted to see what you guys think? And if i should do anything?
move to florida
iamjoe is offline
Old 04-15-2014 | 03:11 PM
Default Replace summer tires with put boat in the water.
ICDEDPPL is offline
Old 04-15-2014 | 03:22 PM
Will you be fine? More than likely but it's also better to be safe than sorry. It will only cost you time and gas to drive to the marina and put a light in, or you can replace a cracked block if not safe. Your call,
rfgonzo is offline
Old 04-15-2014 | 03:45 PM
Indy's Avatar
Member #154
What was the temp during the day today?
Indy is offline
Old 04-15-2014 | 05:41 PM
I'm not too far from the thread starter and the temps today started around 60 and went down from there, it's 40 now. I'm going to gamble on tonight and do nothing.
Stuckonstupid is offline
Old 04-15-2014 | 06:18 PM
Going to be 25 here and I was on the fence, but I'll be throwing a drop light in
RT930turbo is offline
Old 04-15-2014 | 06:25 PM
Indy's Avatar
Member #154
Ehh...I've done worse with my boats. Living in CT I've been stung a few times, I think he'll be ok, especially if it's in a shed or something.
Indy is offline
Old 04-15-2014 | 06:27 PM
bigboat28's Avatar
Yea Artie you might need a light since your elevation is about a mile high, it might get a little colder up there.
bigboat28 is offline
Old 04-15-2014 | 07:02 PM
FWIW, I left the dog's water bucket out last night. Mid morning there was a skim of ice on it. Air temperature was 30 degrees. I would put some heat in if it was my boat.
Padraig
Padraig is online now
