Mercruiser SS riser...point me in the right direction. >
Old 04-22-2014 | 03:01 PM
What are you saying that is not enough cooling for big block? The 454 is a big block right? Are there certain years or versions that have to be used forthe swap.
Godspede619 is offline
Old 04-22-2014 | 03:38 PM
What is the best set for the conversion. I have seen aluminum manifolds/cast iron, water rail / no water rail. What riser?
Old 04-23-2014 | 01:34 AM
496 manifold/risers will work just fine also. You may have to make some modifications to bolt up accessories.
Griff is offline
Old 04-23-2014 | 03:06 AM
The 496 risers are dry joint , will fit, and will cool just fine. The other dry joint system I was referring to LOOKS similar to your current risers but will not work... Its for small blocks.
Chris
Blueabyss is offline
