Drive service question
Old 04-21-2014 | 09:56 PM
Default Drive service question
What is done when you rebuild an XR drive (assuming the upper gear set is good)? What have you paid for this service? I am showing some silver slivers, the drive is 5 years old behind 600ft/lbs torque. Is this something I can do if I have not done it before?
vtown is offline
Old 04-22-2014 | 01:52 AM
If you have never worked on a drive or had someone teach you the specifics, then it is not something I'd recommend.
Chances are at 5 years old, the gear sets are going bad.
Griff is offline
Old 04-22-2014 | 08:09 AM
kaama82's Avatar
After 500 hours on XR gear sets. They will not be good.
kaama82 is offline
Old 04-22-2014 | 08:20 AM
The slivers is usually gear tooth surface material being torn away. Be thankful of the 500hrs you've enjoyed to date & allow someone w/ experience to rebuild them. I don't believe it's difficult but they require special tools as well as knowing how to shim & preload bearings etc.
NASCAT is offline
Old 04-22-2014 | 01:25 PM
RMPRam's Avatar
I have a brand new Mercury XR upper gear set, if you are interested for $1475+ freight.
Gary
ph) 612-247-7081
RMPRam is offline
Old 04-22-2014 | 01:26 PM
For just the gear set or have I misread that?
NASCAT is offline
Old 04-22-2014 | 01:40 PM
Regular price for XR upper gear set is normally almost $1,800.
erichuegele is offline
Old 04-22-2014 | 01:43 PM
Wow, I guess I never realized how much of a $2000 rbld was just the gear sets!
NASCAT is offline
Old 04-23-2014 | 02:40 AM
Where did 500 hrs come from? Very low hrs....like 50. I'm trying to figure out the rebuild cost without gears. 5 years old.
vtown is offline
Old 04-23-2014 | 01:21 PM
No way to figure cost without tearing it down to see what it needs. Even with 50hrs, the gears could be chipping.
Griff is offline
