New drive installation  IMCO SCX >
Old 05-09-2014 | 03:29 PM
  #31
wrinkleface's Avatar
Awesome Petey!! Prop X!!!!
wrinkleface is offline
Old 05-09-2014 | 03:43 PM
  #32
1 MAIDEN AMERICA's Avatar
Watch the wear pads too. I had a screw back out a little and gouge the ring. the rest were a bit loose too.
On my old IMCO SC's one of the round shower caps disappeared so I safety wired the center bolt to a top cap bolt. I did the same on the SCX's.
The fill and drain plugs didn't have magnets on them so I installed them. There [is] a magnet in the sump area, it's just not easily serviceable.
The reservoirs didn't have a provision for the low level alarm so I drilled and tapped for them. Then, with heavy wave action the alarms would go off so I installed a disc/baffle inside, problem solved. I also installed a riser into the hose fitting inside the reservoir to allow for "sludge" accumulation in the reservoir although none has so far.
I started by "blueprinting/truing" the lowers, they needed it BAD!!!, so I don't know what it would've done before but I'm sure it helped.
I lobbed 2" off the skeg=no change
I thinned the skeg about in half(still thicker than a standard SC lower)=no change
Why did you go with a 1.25" propshaft?
1 MAIDEN AMERICA is offline
Old 05-09-2014 | 04:15 PM
  #33
Prop shaft is 1 7/16. Thanks for the info. All new game for me
drpete3 is offline
Old 05-09-2014 | 06:07 PM
  #34
Whew! I thought those were rabbit ear prop hubs.
This is the year I find out about the SCX's. SC's only made it two years, this is the third year.
Fingers crossed.
Old 05-09-2014 | 08:34 PM
  #35
Congrats! Nice hardware...
Cobra100+ is offline
Old 05-09-2014 | 08:59 PM
  #36
Boat Porn, awesome
rfgonzo is offline
Old 05-10-2014 | 05:45 AM
  #37
MarkDonzi's Avatar
Hey Pete,
Installed SCX Uppers on my boat last year.Had to custom fab some stainless plates for the steering rams to work, other than that they have been rock solid so far. Oil changes at 25 hours look like new instead of black and burnt in the old XR drives. Best of luck!
MarkDonzi is offline
Old 05-10-2014 | 05:58 AM
  #38
Man I wish I could go take it out on the water
drpete3 is offline
Old 05-10-2014 | 06:16 AM
  #39
Man I wish I could go with you! Lol. Wont be too much longer now.
Old 05-10-2014 | 07:19 AM
  #40
very excited guys [ATTACH=CONFIG]523189[/ATTACH][ATTACH=CONFIG]523190[/ATTACH][ATTACH=CONFIG]523191[/ATTACH]
ACM does a great job over there....boat looks great! Mike and the crew are great!
Todd
TheGladiator is offline
