24x7 hatch mounting
Old 05-10-2014 | 08:55 PM
glassdave's Avatar
Neno the mind boggler
Originally Posted by vintage chromoly
Today I mocked up the hatch on my 24-7 pantera.
The factory hinges were mounted along the curve of the hatch and were fighting each other when actuated.
In order to get the fulcrums on the same plane or axis I stacked four fender washers on the outside of each hinge. This is just for measurement and mock up.
The plan is to "let" the base of the hinges into the hatch. ]
unless the hinge axis is above the highest point of the arc it will bind. its tough to find a good setup for these curved hatches. Rob I'd still take that odd single big eddie marine stainless one I had laying around and stick it right in the middle
08 OPA High Points Champion
glassdave is offline
Old 05-10-2014 | 09:00 PM
northernoffshore's Avatar
http://www.starmarinedepot.com/seach...FU_l7AodNigAFg
northernoffshore is offline
Old 05-10-2014 | 09:14 PM
PigNaPoke's Avatar
Originally Posted by northernoffshore
Phragle I believe these are the hinges I have on my resin bucket... They're kind of small but the hatch isn't a ton.
PigNaPoke is offline
Old 05-11-2014 | 03:14 AM
vintage chromoly's Avatar
Hey Dave. There is enough room between the top of the curve and the deck to let the hatch actuate with no binding. As long as the axis is the same on both sides it opens with no binding or twisting whatsoever.
vintage chromoly is offline
