need damaged ssm#6 low case >
Old 05-11-2014 | 01:45 PM
[ATTACH=CONFIG]523267[/ATTACH]
bdavies is offline
Old 05-11-2014 | 02:03 PM
Originally Posted by Enough 4 Play
My source has been revealed. Lucky that blade did not catch the other prop and drive on the way out. I wonder if the prop shaft is bent or any other damage to the internals. I would have all of the specs checked before that drive goes back together.
It really is surprising it didn't hit the other prop considering that the tips of the props are less than 3/4" away from each other. We are going to give both of them a thorough once over.
Eddie
Young Performance is offline
Old 05-11-2014 | 02:20 PM
Coolerman's Avatar
PF Marine
Sure they didn't hit something? It might an illusion, but it looks like a chunk missing from the other skeg...... That is some pretty good carnage tho!!
Coolerman is offline
Old 05-11-2014 | 04:01 PM
That one was there already I believe.
Old 05-11-2014 | 09:11 PM
SummerObsession's Avatar
Herrings? I couldn't quite make it out on the prop.
SummerObsession is offline
Old 05-11-2014 | 09:12 PM
yep
skater40 is offline
Old 05-12-2014 | 06:48 AM
We pitched a blade off of a 388. It didn't do quite the damage yours did, but it did strike the bottom of the cavitation plate and bend the prop shaft quite a bit.
davidwademarine is offline
Old 05-12-2014 | 10:36 AM
littledcsrodshop's Avatar
Hold on, let me get my touch up brush back out..
littledcsrodshop is offline
Old 05-12-2014 | 12:16 PM
You don't need it for the prop, but you will need it for where the drunk idiot with a pontoon boat ran into the side.
Old 05-12-2014 | 02:02 PM
CLA
Did you do this at Ticfaw running out of the canal? If so I was next to you in the eliminator. My ol lady said she saw everything fly through the air.
CLA is offline
