First Start up of the season vids....POST 'EM UP >
Old 05-22-2014, 07:12 PM
Need a bigger cam
12meter joe is offline
Old 05-22-2014, 07:28 PM
Here is close to the first startup this season. Don't mind the cover, just pulled it off the lift so the marina could adjust the bunks
https://www.youtube.com/watch?v=e82cOFoklc4
sleev-les is offline
Old 05-22-2014, 11:15 PM
SORE MEMBER
Wobble's Avatar
Started it with 50/50 oil/diesel pressure started maxed out at 80psi and went down to 30 on warm engine, 3 changes with rotella and i am seeing 60 psi at idle. intake is welded up and it's looking like I can go boating. I have 45 gallons of water/ diesel contaminated oil if anyone has a use for it. One more change and I'll put another 12 quarts of v-twin in. Talk about a close call.
Wobble is offline
Old 05-23-2014, 04:05 AM
http://www.youtube.com/watch?v=Ik00zEudKCo
http://www.youtube.com/watch?v=e5J1LGaKoQk
this was the start to our seson
mrmalo32 is offline
Old 05-23-2014, 07:12 AM
SORE MEMBER
Wobble's Avatar
Originally Posted by Black Baja
Careful with the diesel it's hard on rubber seals. I learned that one the hard way - switched to using transmission fluid...
Thanks for the heads up. I have the brass lined air gap intake, gaskets must have been seeping and the water corroded the gasket surfaces to the point that a seep became a sudden flood. Incredible mess by the time I idled to a ramp.
Wobble is offline
Old 05-23-2014, 08:41 AM
Ok,,, here's my little boat... :0)...
http://youtu.be/SvQKEvYW8QU
Nordic Bear is offline
Old 05-23-2014, 08:53 AM
Originally Posted by mrmalo32
Those are some tough sounds engines right there. Nice!
Nate5.0 is offline
Old 05-23-2014, 10:17 AM
TooLateVTEC is offline
Old 05-23-2014, 12:21 PM
Heres my little powerplay.
http://www.youtube.com/watch?v=9PPcIEP3P48
Looking for 75+ this year
New 383 w/ Alpha SS
chrisf695 is offline
