Home made drive showers?
Old 06-06-2014 | 07:25 AM
Originally Posted by Big Block
Looks like brake line?
Correct, 5' one to be exact. You win a cookie
Tubing bender, 1/8" drill bit, tape mesure, sharpie and a cold beer
Once bent into the shape i drilled a dozen or so 1/8" holes on the side of the tubing.
Probable acts more like a pressure washer then a cooler, LOL.
92nsx is offline
Old 06-06-2014 | 11:06 AM
they say it only drops the oil about 4 to 5 degrees not worth the hassle you should use a power steering cooler run your raw water through it and a pump for the oil to do the job right
Thebros is offline
Old 06-06-2014 | 11:17 AM
thinking about trying this one.
[ATTACH=CONFIG]524361[/ATTACH]
12meter joe is offline
Old 06-06-2014 | 11:22 AM
Simrek has testing showing 50+ degree temp drop. Certainly worthy of considering the hassle. In high performance anything, I'm a big fan of all the cooling you can stand.
Pilotpete is offline
