Wasn't boatless for long..... >
Old 07-29-2014 | 08:11 AM
Originally Posted by low_psi
exactly!!! You basically just went through the winterization process too..... No need to run antifreeze, just let them drain... I know its a no-no to fog the Optimax, not sure if its the same for the EFI motors....
My service manual isn't here yet, but I was told for winterization I'm supposed to mix an auxillary tank with a little 2 cycle oil, stabilizer and gas, and let it run on the muffs for 10 minutes. This motor has a freshwater flush input, so I will probably skip using flush muffs on the L/U. We'll see when the manual arrives.
Speedracer29 is offline
