Best starter??
Old 08-04-2014 | 07:51 AM
Default Best starter??
I have a starter that the solenoid is not wanting to work on %100 of the time. At times I have to turn the key a few times to get it to crank. I can hear it trying to engage. Now I don't want to have to replace this thing twice and I have heard to many horror story's of guys tossing brand new starts in and having them fail in a few hours. If I'm going to coat myself in lube and squeeze down in there to replace it... I only want to do it once.
Thx
Mike
mptrimshop is offline
Old 08-04-2014 | 08:24 AM
Wobble's Avatar
SORE MEMBER
it's probably the mercruiser starter relay by the mercathode panel. If no you cant beat a reduction gear starter from summit or jegs
Wobble is offline
Old 08-04-2014 | 09:49 AM
I can hear a clicking noise from the engine compartmant when I turn the key. So was just assuming it was the start getting jammed trying to engage. Maybe I'm wrong.
Old 08-04-2014 | 10:05 AM
Wobble's Avatar
SORE MEMBER
Merc uses an additional relay to boost voltage to the actual starter solenoid, have someone use a test light to see if power is going through the merc relay when key is turned before changing starter. I changed mine and a buddies this year, they are available on e-bay cheap
http://www.ebay.com/itm/New-Mercury-...01eccd&vxp=mtr
Wobble is offline
Old 08-04-2014 | 10:13 AM
T-Mone's Avatar
T-Mone
replace the solenoid that is in the harness on the engine looks like a trim solenoid. They are mechanical inside an when go bad they dont hold the voltage when cranking. I had similar prob that fixed my issue.
T-Mone is offline
Old 08-04-2014 | 01:32 PM
Sounds like that will be my first move.. Thanks guys
If I do need a starter what ones have you hits had luck with ?
Old 08-04-2014 | 02:12 PM
a merc one...theirs a guy selling them in the classifieds under parts reasonable..merc starters....
FIXX is offline
Old 08-04-2014 | 02:17 PM
i agree,the merc starters are good.most of the time it is the slave solonoid not the starter.
mike tkach is offline
