Why are headers so expensive? >
Old 08-27-2014 | 09:50 PM
  #61
Originally Posted by H20 Toie
if you wait for the failure then your going to be buying a motor and headers , the 525 is a great motor and you can get a lot of hours out of them. at 300 hrs you should be changing the valve springs get new headers and be good for another 300 hrs
you are lucky to have gone this long
the hardin marine headers are a replacement
at 300 hours, you should definitely be doing valve springs and also consider rocker arms. and H20 is right.. if you wait until your headers fail to check, it will be too late.. ask me how I know..
An easy (and safe) way to pressure check the headers while they're still on the boat is with compressed air. You can use a leakdown tester or make a homemade one consisting of a pressure regulator, 1/4" ball valve and pressure gauge and a bunch of fittings to get it all together. First, block off the water inlet and outlet with 1" rubber furniture stoppers and hose clamps. Then hook one end of the tester to an air compressor and the other end to the 3/4" fitting on the header. Then open the small blue drain plug and let some air in to purge any remaining water in the headers so they're empty for the test. Next, set the regulator to 60 psi, open the valve to fill the header with air, close the valve, then monitor the gauge to see if there is any loss in pressure. It really works great and will tell you if you have any leaks before they really bite you. It's easy, safe and you can do it pretty regularly without taking the headers off. Here's what mine looks like.
[ATTACH=CONFIG]528457[/ATTACH]
Attached Thumbnails Why are headers so expensive?-10572097_10204507220988970_3837323801271230428_o.jpg
HyFive578 is offline
Old 08-28-2014 | 08:01 AM
  #62
They are very expensive I think because of the materials being used. If you are out of budget stay away from those mentioned brand look for after market that the price is half.
chardricketts is offline
Old 08-28-2014 | 09:52 AM
  #63
On Time's Avatar
Neat little device! I am going to do that!
On Time is offline
Old 08-28-2014 | 10:56 AM
  #64
Originally Posted by 1 MAIDEN AMERICA
You have to charge a lot so that you can afford to keep an employee in the complaint department. Vicious circle I tell you.
LOL, Funny
JAIME is offline
Old 08-28-2014 | 11:43 AM
  #65
VoodooRob's Avatar
My company produces motorcycle exhausts, we use various grades of titanium, carbon fiber, carbon and stainless steel in the different applications and models we make. After buying our boat with the CMI exhaust and reading about the experiences I looked in depth at creating something along the lines of CMI. At the end of the day, producing a CMI like exhaust would have been a substantial up front investment and not being in the Marine industry a large gamble for my company. The margin would have been OK and pricing would have ended up slightly under CMI. So not a smart business decision for us if we went into production. The reason automotive headers are so much less expensive is demand, supplier competition and shear production volume.
VoodooRob is offline
