140mph 22ft I/o ??????
Old 01-15-2015 | 10:59 PM
  #41
Originally Posted by River_Runner
They run an Australian made Bullet 21'
Bullet is only one manufacturer over here on the I/O ski race market and by no means the biggest seller!
FYI the only reason they dont run longer is rules limit them to 21' from nose to back of running surface.
These days it probably goes in this order (I/O configuration):
1. Force Boats (by a long way, probably have 80-90% of the market right now) (they make everything from an 18-24 footer. The topend guys running big power mostly run their 21 and 23 which is technically a 21 bottom with buit in pod and higher sides)
2. Velocity (relatively new and arguably a knockoff of a Force with mods)
3. Connelly (one of the oldest running makes in competitive ski racing, one several world titles over the years. Older design but proven fast and good handling boat. Downside is its high speed cornering ability vs the new shapes.)
4. Bullet Boats (Just released a 2150 which is technically 21'. Relatively unproven so far. 1st one crashed in its 3rd outing and sunk. Cause still being investigated as it resulted in fatality. Again, looks very much like a Force knockoff!?)
Revolution
Cyclone Boats (one a world water ski racing title in 1999 and just released a brand new 21. 1st I/O hasnt even hit the water yet.)
There is plenty others but the above are the main players.
I should note these boats run anything from NA 6litre engines right through to 1800hp 572CI (Max allowable cubic capacity). Mercurys 1350 packages are very popular these days for their ease of setup, reliability and ability to run pump gas. Top speeds of the boats is arguable as they are setup for ski racing not boat racing but they have been clocked at 139mph towing 2 skiers and regularly sustain 120+mph in races. I have no doubt some could easily break 150mph!
The most impressive thing these days with the newer hull designs is their cornering speed in rivers. The boats go around like they are on rails where they used to purpoise when you pushed them in too hard and sometimes spin out.
Kurt Hamilton is offline
Old 01-15-2015 | 11:12 PM
  #42
I would like to see the bottom of the boat , ill bet blueprinted is a understatement .and ill bet it now handles rough water like a early '80s stars and stripes .
airjunky is offline
Old 01-15-2015 | 11:36 PM
  #43
I remember the guy up in nh 20 years ago that got 99 out of a 20' sea ray custom shortened merc outdrive that was something there .he has got to be on this forum somewhere
airjunky is offline
Old 01-16-2015 | 01:28 AM
  #44
JMP
Check out this Glastron
http://www.liveleak.com/view?i=89e_1310693288
JMP is offline
Old 01-16-2015 | 05:03 AM
  #45
Originally Posted by JMP
Thats cool I have one with a 90 johnson on it .
buck35 is offline
Old 01-16-2015 | 05:59 AM
  #46
Originally Posted by payuppsucker
There's a guy on here that had a twin turboed LS motor in a Checkmate that ran up there pretty good. I think he was over 1500hp in front of a wet sump #6. Screen name Checkmate ???.
Check300
hadleycat is offline
Old 01-16-2015 | 11:08 AM
  #47
Revolution
My 22 is single stepped hull I guess contributes it getting squirrelly above 80mph. My question to you is do any of these competitive ski boats run extension boxes? Do they lower the x dimension to gain
More control? Other than running huge hp engines packed in small hull's what does it take for these boats to get to and handle at the speeds they run? 100 or 110+
doubleduecedonzi is offline
Old 01-16-2015 | 11:19 AM
  #48
SB
Let's not forget Geoo with his Mighty Mouse ! One, if not the, most famous small Donzi's ever.
Click for larger picture: http://www3.telus.net/spectrasonly/GEO.jpg
SB is offline
Old 01-16-2015 | 12:20 PM
  #49
Sammie Nassar was no joke, I bought my first new boat from him a 1989 Checkmate 25 Convincer. In 1990 I took over his shop Action Marine and opened Action Auto & Marine repair. At the time Sammie had a very fast small Checkmate and a 30 Cat with 2 twin turbo 1100+ HP engines that ran over 140 MPH. He did a lot of custom work for Merc at lake X and knew how to get speed out of a boat.
brian41 is offline
Old 01-16-2015 | 02:39 PM
  #50
Revolution
All of those boats are truly works of art. I know I love watching all the sprints online (southern 80)
Thanks for the good info!
River_Runner is offline
