Difference between prop speed and rpm? >
Old 03-19-2015 | 08:43 AM
Default Difference between prop speed and rpm?
Are there gauges for prop speed readouts?
polsprung is offline
Old 03-19-2015 | 08:48 AM
Tachometer/drive ratio is pretty accurate...
Cole2534 is offline
Old 03-19-2015 | 08:49 AM
Wouldn't the drive ratio determine the prop revolutions? Here is a link to explain.
http://www.go-fast.com/sterndrive_gear_ratios.htm
CrownHawg is offline
Old 03-19-2015 | 08:51 AM
and gps,,then you get prop slip which will get real speed of prop.
sutphen 30 is offline
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
http://www.livorsi.com/catalog/data_tach.htm
We've put these in a few boats in the past, but not sure if they are still offered.
Sydwayz is offline
Old 03-19-2015 | 12:37 PM
The difference between actual and theoretical boat speed is prop slip/efficiency the lower the slip in percentage the more efficient the hull/wheel combination. Of course trim/sea conditions/wind/load etc will all play into the ultimate result. Typically keep the tabs up to neutral, trim to just under prop blow out and limit the weight of your gear on board to attain your max speed. Then compare actual to theoretical.
I'CE is offline
Old 03-19-2015 | 01:01 PM
Mbam's Avatar
Offshoreonly Advertiser
Take a look here also http://www.go-fast.com/prop_slip.htm
I just want to point out that the term "prop slip" is a little misleading.
Mbam is offline
Old 03-19-2015 | 04:30 PM
Comanche3Six's Avatar
That's a handy chart.
crankshaft rpm ÷ gear ratio = prop shaft rpm
Comanche3Six is offline
Old 03-20-2015 | 03:40 PM
It seems like 'prop slip' is implied through a formula/ratio which is not what I'm after.
I need a sensor that will determine whether prop is in mid-air or underwater. I'm looking for a measure of prop slip over a duration of multiple times a second (e.g. 200hz).
Is there a sensor to measure propeller resistance?
Old 03-21-2015 | 03:19 PM
hate to ask, but what for and why. if the wheel is mid-air/out of the water prop. slip is 100%. are you trying to measure blade load as it comes into aeration and re-enters and becomes loaded?
prop slip ratios are not implied they are real. are you attempting to possibly design a wheel with minimal hydraulic resistance? maybe ask the question in the propeller section.
I'CE is offline
