800hp through an xr drive
#101
Jupiter---- Your answer is exactly what I expected from you..
There are a whole bunch of guys out there with Bravo's that would benefit from such a gear set...
#102
Was still employed when he owned the F-4. I remember running 86 MPH at LOTO in it. We ran hard enough to break the driveshaft cover after the Shootout.
#103
What if there was a gearset available that for most applications up to 800 hp/800 ft lbs. that eliminated the"gear" failure of the XR ?? Would you all be interested in buying a set ??? What would you be willing to pay for them ????
And let's not be ridiculous with your answers about the cost.
#104
#105
Which Arneson's or six's are on edge with 800 HP?
#106
What about the vertical shafts that like to snap like twigs? And what to do about popping the top cap off the case when the drive walks those new gears up thru the roof? Or splitting the case at the top? Or the busted/twisted prop shafts? Then there are the Bravo props that throw blades like Frisbees! It never ends...
#107
He is referring to an old asd6 arneson drive, which would not last with 800hp either. However Rik sells upgraded gear sets for the older asd6 that can handle much more power than the original design. That old asd 6 was designed in the 80s when 440hp was impressive
#108
What's really gross is the Merc Bravo XR drive is a hand grenade even behind power that it's supposed to be rated for. How many failures have we seen behind 525's, never mind 600's. And even more mind blowing is we are so numb to failures that they are expected and accepted. Can you imagine buying a new Ford Superduty and bragging to your buddies that you got a full season out of the rear end????? Absurd.
If someone told you 25 years ago they would be running triple digits in a 35ft +\- pleasure boat with 525hp a side you would have told them they were crazy.
Someone mentioned bragging about an f350 rear end lasting a year and how it sounds absurd. Drive that truck and have something lift the rear end while you are driving at 4000 and drop it back down the the pavement before you have a chance to let off...constantly, and see how long the driveline lasts
#109
#110
hmmmm.. one of these is designed to last a lifetime one is not
