The project begins
Old 07-20-2015 | 09:35 PM
  #31
Tinkerer's Avatar
Just like building with tinker toys. The tools are just more expensive. And everything must be real clean. The fun is that there are some parts that I have never used before. JESEL shaft rockers and JESEL belt drive for the cam. I will have to learn how to properly install and shim the shaft rockers. No hurry. Take time to do it right.
Tinkerer is offline
Old 07-21-2015 | 08:57 AM
  #32
Who makes that oil pan?
Pokher Ace is offline
Old 07-21-2015 | 10:09 AM
  #33
Setting up shaft rockers is much easier than stud mounts...
Black Baja is offline
Old 07-21-2015 | 06:35 PM
  #34
Tinkerer's Avatar
I haven't taken all of the pieces out of the box yet. Does the kit come with shims? I understand that you shim the rocker assembly up so that the travel is centered on the valve stem just like regular rockers and then use an adjustable push rod for measuring length.
Are there any tricks or special things I should know about the belt drive?
Tinkerer is offline
Old 08-19-2015 | 09:11 PM
  #35
Tinkerer's Avatar
Finally dropped the engine in the boat last Sunday late afternoon. Installed the transom assembly onto the extension box tonight and what do you think are odds of the engine alignment tool going into the coupling when the engine is just sitting on the back mounts with a 2x4 and a scissors jack holding up the front. I just eye balled it. It isn't perfect but the tool went right in. I have to shim up the back of the engine about 1/4 inch so that the shaft is centered on the hole in the front of the box.
Tinkerer is offline
Old 10-25-2015 | 08:23 PM
  #36
Tinkerer's Avatar
Work has kept me from finishing the project in time to get it on the water during warm weather. I did manage to get it on the water today for testing. Running the same outdrive and prop ( Bravo labbed 30 )
Prop shaft is now 2 inches above the bottom of the boat. I still don't have the interior or the engine cover on. Good news is the boat got on plane but ran like crap. I took the carb off of last years engine that was dialed in almost perfect. It ran SOOOO rich it was fouling out the plugs. I made two try's to get on plane and put it back on the trailer. I think I am going to have to go to a 5 blade because once on plane it seemed to slip a lot. I will have to dial in the carb and try it again. So far so good.
[ATTACH=CONFIG]546941[/ATTACH]
[ATTACH=CONFIG]546942[/ATTACH]
Attached Thumbnails The project begins-img_20151004_154636124_hdr.jpg   The project begins-img_20151004_154701425_hdr.jpg
Tinkerer is offline
Old 10-25-2015 | 11:59 PM
  #37
Awesome man. Love when a project comes together. Did carb get gummed up sitting with fuel in it?
hogie roll is offline
Old 10-26-2015 | 05:52 AM
  #38
When I went to a shorty on my Profile 28 I had to run a 5 blade and the cav plate extension was a must. Not sure what power you are running but I have a decent selection of 5 blades but they are 30p and up. Herring, Maximus, Hydromotive. You are welcome to try them out (I am in Lansing) and I will sell them reasonable.
JRider is offline
Old 10-26-2015 | 05:52 PM
  #39
Tinkerer's Avatar
Right now I am running 750 HP with a 1.34 ratio drive. I would like the 30 pitch. What prop worked best on your boat?
Tinkerer is offline
Old 10-26-2015 | 05:54 PM
  #40
Tinkerer's Avatar
No the carb didn't get gummed up it is just jetted for the 509 that was in the boat last year. I thought it would at least be close. BOY was I wrong. I never let fuel sit in the tanks or carb for any length of time more than a month. I pump the tanks dry and run the carb dry also.
Tinkerer is offline
