Fastech 312 Problems
Old 05-26-2015 | 01:28 PM
was actually thinking of trying to borrow 24s from someone to try. the 26s seemed to pull ok mid range these motor just aren't enough for this boat. that i know but they're reliable and don't have to many problems.
Bmichels8587 is offline
Old 05-26-2015 | 01:43 PM
VoodooRob's Avatar
You should still be able to pull low 60s. Talk to Brett at BBlades to get props worked. He knows the Fastech boats well and will get your current props dialed in.
VoodooRob is offline
Old 05-26-2015 | 02:13 PM
Good advise.
Rattlesnake Jake is offline
Old 05-26-2015 | 03:33 PM
I'm no expert, especially with the fastech, but 28's on 310's really seams to be a mismatch to me
88242LS is offline
Old 05-26-2015 | 03:57 PM
without knowing the gear ratio it will be hard to tell you if the boat is over pitched or not. agreed with most. 28's seem a bit steep in general.
1MOSES1 is offline
Old 05-26-2015 | 04:06 PM
Agreed, that was gonna be my next question, I don't think Formula played with the ratio on the 312, but u never know, especially with stock power, my 303 has 1.36 but I'm running 502's
88242LS is offline
Old 05-26-2015 | 04:08 PM
Those props are way to big IMHO. I have a 353 with 502's and it runs a factory 28 pitch prop. I would think you need a 26 or possibly something eve smaller
FANTAZ28 is offline
Old 05-26-2015 | 07:07 PM
Check fuel pressure and and change fuel filters.
Unlimited jd is offline
Old 05-26-2015 | 08:33 PM
t500hps's Avatar
21 and 42 footers
I had a 312 and every 312 I ever heard of came with 1.65 Bravos........the 454 mag and 502 mag boats came with 30's. (My 312 had 502s and 30's)
Now, maybe those are the right props but somebody put 1.5 bravos on the boat.......making them too big.
t500hps is offline
Old 05-26-2015 | 09:48 PM
VoodooRob's Avatar
^^Very Good Points Made^^
