Herring or Updates Skegs
Old 09-11-2002 | 10:08 AM
Offshore Roller
Default Herring or Updates Skegs
Curious, what are the differences on the new mercury number six skegs and the herring skegs. On a Straight Bottom Vee Hull what differences will we be seeing in mph and handling? (Projected) Pictures of Swept back and herring skegs are appriciated.
--Roller
Old 09-11-2002 | 11:59 AM
cougarman's Avatar
Default Skegs
Basically the older ones have more
meat to work with,when welding them
etc. They are put on a CNC
machine and does his magic.
A test was run on them in a controlled
environment ( Lake X ). It was on a
cat, Herring's skeg was 3 mph faster.
Apparently they kept swithing the old drives
and Herring's drive's back and forth
to make sure it wasn't a fluke. And every
time Herring's skeg was 3mph faster.
Just what I was told
Cougarman
cougarman is offline
Old 09-11-2002 | 02:58 PM
What is a Herring skeg and what does it look like? Could it be applied to the bravo skeg?
cobra marty is offline
Old 09-11-2002 | 03:31 PM
cougarman's Avatar
Default .
I was told the existing skeg is modified too
make a Herring Skeg, not sure if it is factual,
just what I was told.
The internal housing is remachined after the
welding is done , because it will warp inside a little bit.
Old 09-11-2002 | 05:53 PM
timucin's Avatar
any pictures to see the difference ?!?
pls-pls-pls
timucin is offline
Old 09-12-2002 | 08:35 AM
cougarman's Avatar
Default Swept Back
Notice the front is cut back on quite
an angle.
Also the back edge is brought
right up to the propeller which also
helps improve handling.
Old 09-12-2002 | 08:44 AM
cougarman's Avatar
Default Original # 6 Speedmaster
Not the greatest sideview, Trailer is
blocking part of it. Anyway's I think
You get the idea.
You see the Skeg taper's from both
the front and the back.
And you notice the back edge is much
further from the back side of the propeller.
Old 09-12-2002 | 09:29 AM
Thanks, pictures are worth a 1,000 words. But is the Herring skeg the same as the swept back?
Old 09-12-2002 | 09:52 AM
cougarman's Avatar
Default .
From what I understand, you can look
at them visually and they are the same.
To check them on a CMM Machine Herring
has a few tricks.
To run Herring in the water, supposively
Herring is faster as stated above.
Cougarman
Old 09-12-2002 | 10:59 AM
timucin's Avatar
cougarman thnx for pics.
timucin is offline
nocigarette
Classic Offshore
15
01-20-2007 09:18 PM
txriverrat2001
0
11-20-2006 01:09 PM
SLINGSHOT
12-18-2003 07:52 AM
HOUSTONPROP
14
02-04-2003 06:01 PM
kwb
4
05-09-2002 05:45 PM
