alpha one not pumping water help please!!!! >
Old 07-26-2015 | 02:52 PM
Default alpha one not pumping water help please!!!!
i have a alpha one in a four winns liberator. the hose is connected to break in new motor. i disconnected the water intake line going from outdrive to engine. with the hose full blast and the engine running it barely drizzles water out.so my outdrive is not pumping sufficient water.. the water pump and impeller are both new. i dont know where to look for whats wrong!!. please help guys. hell even call me if you want 602-349-7277 my name is mike. or reply on here.
thanks !!!!
mike08kurtz is offline
Old 07-26-2015 | 03:09 PM
Something wrong with water pump, there are several good U-tube videos on changing, maybe 1/2-1 hr. to complete the job.
GLENAMY 242SS is offline
Old 07-26-2015 | 03:42 PM
BUP
So your drive is installed and you are NOT running water thru the outdrive pick ups in the lower unit - IF SO you just burned up your complete impeller and housing and seals and water tube and water tube pocket and cover.
Or am I wrong about not have a water supply to your outdrive water inlets ?
BUP is offline
Old 07-26-2015 | 03:47 PM
i have water going to it. goes in the lower unit. via motor flusher coming off the garden hose from my house...... the only hose i took off was the hose that goes from the outdrive to the engine the one thats connected to the power steering cooler i believe. .... to see if water was making it into the engine. water just barely comes out of the drive when running.
Old 07-26-2015 | 03:52 PM
BUP
You most likely will need a complete impeller kit including the housing and the lower base . then check the water pocket and cover in the upper underside, it needs to be perfect with no melting or leaks ' - it is gasket sealed. Thats the portion where the water tube on top of the impeller housing slides up into.
BUP is offline
Old 07-26-2015 | 03:58 PM
alright thanks! its a brand new impeller. i got the complete kit, hopefully all is well. im gonna check where you said to, im gonna take the drive off right now.
Old 07-26-2015 | 04:58 PM
when i drained the oil in the drive there was water in it. brand new oil. any ideas where to start looking?
Old 07-26-2015 | 06:03 PM
Too Stroked's Avatar
Time to pressure test the drive. That's the only sure way to find out where it's coming in. Could be as simple as the seal / washer that's on both the Drain and Vent screws. Then again it could be one of a number of seals in and around the drive. I'd suggest taking it to a shop you can trust and have them go through the whole drive.
Too Stroked is offline
masi242's Avatar
Just a guess put there are some small O-rings that need to be seated in place when you put the drive together could you have missed one?
masi242 is offline
