what speed should I expect? >
Old 10-10-2015 | 07:30 PM
I would think that those motors should push the 25 just fine up to 4800. Have you checked the compression or have you done a leak down. Top end my be weak. How many hrs on this thing. Also post a pic would love to see what you got
Drew555 is offline
Old 10-10-2015 | 07:31 PM
I just googled pics of the boat (well same boat). It does not appear to be a 24 degree bottom and from the style of boat, I can not for the life of me figure out why it would have bravo 2's on it. B2;s are deep drives to swing larger diam. props for diesel cruisers.
1. you need to figure out what drives you really have
2. if they are in fact B2's ( Idont kknow B2's well so this may be wrong) but i think the extra length is in the lower.throwing some shorties on there may dollar for dollar give more speed and better handeling than more motor.
phragle is offline
Old 10-19-2015 | 04:22 PM
Attached is a picture of the engines. The SNs are wore off the carb covers. I can fined castings if someone can advise where to look.
I was hoping that "Performanced Tuned Bravo 3" would point to whether its a MAg or something else.
here is the url of the image if it doesnt load: https://www.dropbox.com/s/ozwyo1j4vj...G0069.jpg?dl=0
superderek3 is offline
Old 10-19-2015 | 04:54 PM
7.4's generally indicates 330 crank hp
I can't imagine it having bravo 2's on it
here's a pic of a bravo 2
http://www.go-fast.com/bravo_2.htm
here's a pic of a bravo 1
http://www.go-fast.com/bravo_1.htm
notice the difference in the lowers ?....which do you have ?
JaayTeee is offline
Old 10-20-2015 | 09:12 AM
They are Bravo 2s. The boat did not come with them, it came with 3s. Someone changed em to 2s at some point. I had a marine mechanic verify by SN, and also the oil drain plug is behind the prop, which I understand to be a unique characteristic of the Bravo 2s, not 1 or 3.
I have a SN off one of the motors: 0F066007 (I still cant determine if thats 7.4 or mag, the online lookup returns both as an option...) The good news is the carb covers does indicate 4200-4600 max rpm which i guess indicates a 7.4 non-mag. right?
Here are 2 pics of the boat, one where you can see the drives.
https://www.dropbox.com/s/ugosy9iwg4...12.07.jpg?dl=0
https://www.dropbox.com/s/hhmalgckoy...12.21.jpg?dl=0
The Marine mechanic that verified they were 2s also recommended that i play around with the trim, and trim up some. He thinks i'll gain quite a bit of rpm by doing that.
Old 10-20-2015 | 09:47 AM
dcb
Oil change plug is behind the prop on a B-1. The picture is hard to see, but those look like B-1s.
dcb is offline
Old 10-20-2015 | 10:32 AM
i'll try to get better profile pics of them this weekend. Sorry for the confusion and thank you everyone for the help as i figure this out...
Old 10-20-2015 | 12:37 PM
It should be a 55-60 mph boat. You are going to need to drop the pitch of the props to get your rpms up. Are you trimming the drives out once you are up on plane?
21 or 22" four blade props like a Rev 4 or Bravo 1 (prop, not drive I know it's confusing) will probably give you the best performance
rexcramer1 is offline
Old 10-20-2015 | 01:17 PM
I'm not trimming out once on plane but now recognize it's something i should be doing. I'll need to experiment with it. Boat is now winterized so it'll be a while till i can come back with test results.
Old 10-20-2015 | 02:04 PM
Just trimming out will give you 5-8 mph
