Like Tree0Likes
F1 rules on Boats (X Dim)
Old 09-16-2002, 10:57 AM
Registered User
BAJA WILL's Avatar
My Boats: Don't even mention the word boat
Default F1 rules on Boats (X Dim)
I don't know allot about this and would like to know more. What is the weight and X dim allowed in F1 APBA
WILL
BAJA WILL is offline
Old 09-16-2002, 12:11 PM
Offshore Addiction
Per APBA page 160-161 of the handbook
12. X-Dimension - For the 2002 racing season, the Factory I and Factory II Classes will be limited to maximum drive heights. The maximum drive height for all boats eligible to run standoff boxes shall be limited to the centerline of the propshaft being a minimum of 2 below the bottom of the boat as measured with a straightedge off of the aft running surface directly in front of the drive. (strakes and notches excluded) For purposes of measurement, the centerline of the propeller shaft must be parallel with the aft running surface. All other boats in Factory I and Factory II Classes shall be limited to the centerline of the propshaft being a minimum of 3 below the bottom of the boat using the same measurement procedure detailed above. APBA Offshore, at its discretion, may further regulate drive heights for parity or safety reasons.
Old 09-16-2002, 12:13 PM
Offshore Addiction
Per page 149 of the APBA Handbook
Dimensions for Factory I Single Engine
Hull Type: Monohull
Length: 24- 0 minimum to 30-0 maximum true length (note: 6 tolerance rule does not apply for length measurement purposes)
Beam: 86
Weight Minimums:
Length Weight w/ HP 500 Carburated Weight w/ HP500 EFI (Injected)
24' 4100# 4350#
25' 4225# 4475#
26' 4350# 4600#
27' 4475# 4725#
28' 4600# 4850#
29' 4725# 4975#
deanpp
1
08-05-2007 06:26 AM
aero-offshore
24
03-17-2004 11:23 AM
Gumbydammit
06-21-2002 01:14 PM
phughes69
06-06-2002 12:17 AM
phughes69
04-30-2002 01:23 PM
