Stagger Question
Old 09-27-2015 | 12:40 AM
Originally Posted by bck
Can't really get much closer with the transom assembly's. I can measure whatever you want. Mine is about as tight as you can get.
That's full stagger, short is when the heads don't overlap from the front engine to the rear
Unlimited jd is offline
Old 09-27-2015 | 06:32 AM
What kind of boat is that?
indysupra is offline
Old 09-27-2015 | 07:47 AM
glassdave's Avatar
Neno the mind boggler
38 Larry Smith Scarab
08 OPA High Points Champion
glassdave is offline
Old 09-27-2015 | 12:40 PM
14 apache's Avatar
[ATTACH=CONFIG]545729[/ATTACH]
Attached Thumbnails Stagger Question-297080d1189039684-star-chaser-pics-eric-boat-20070013.jpg
14 apache is offline
Old 09-27-2015 | 01:24 PM
bck's Avatar
bck
Charter Member#568
I'll be able to measure it in the next couple days
Straight bottoms and flat decks
bck is offline
Old 09-27-2015 | 02:00 PM
Thanks bck also if you don't mind can you measure from the front of the lower pulley of the rear motor to the same spot on the front motor .
Cheers RG.
Rick G is offline
Old 09-27-2015 | 02:16 PM
bck's Avatar
bck
Charter Member#568
The engines are out right now. That's how I can get all the other measurements. The front and rear motor mounts and bellhousings are in it, but no motors.
bck is offline
Old 09-27-2015 | 02:39 PM
Okay how about motor mount distances rear motor to front motor front mount on each motor .
Thanks Rick G.
Rick G is offline
Old 09-27-2015 | 06:03 PM
14 apache's Avatar
[ATTACH=CONFIG]545745[/ATTACH]
Attached Thumbnails Stagger Question-543512d1437882407-36-cigarette-wide-body-originally-slapshot-phone-056.jpg
Old 09-27-2015 | 06:45 PM
that looks like a real pleasure to work on!
mike tkach is offline
