Armed on surface drives
Old 10-21-2015 | 07:34 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Originally Posted by JRider
Minor amount to have to worry about? A minor amount of money to fill in the notch? What deems it needing to be addressed or not? Looks pretty large to me.
[ATTACH=CONFIG]546754[/ATTACH]
It doesn't require the entire notch to be filled.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 10-21-2015 | 08:09 PM
Doubt it will be much different or minor in cost to totally fill the notch
JRider is offline
Old 10-21-2015 | 10:55 PM
Rik's Avatar
Rik
Originally Posted by JDB1981
The motors are around 800 hp
Power is not a problem
Rik is offline
Old 10-22-2015 | 07:29 AM
JDB1981's Avatar
thanks for the replys I was thinking surface drives would definitely have less drag and you can control the drive height
JDB1981 is offline
Old 10-22-2015 | 08:00 AM
As high as those drives are I don't really see a big reduction in drag. But how many times have you heard someone say they blew an Arneson?? about 1/1000 > of a #6
fastdonzi is offline
Old 10-22-2015 | 08:10 AM
I think the hull would benefit from the stern lift of the arnesons. Notice how the motors are mounted pretty far forward?
JDB1981, does your boat have the mini center pod?
What is the weight of difference of an Arneson VS #6?
JRider is offline
Old 10-22-2015 | 08:49 AM
I suggest you find out what updates have been done to the bottom first. The F34 has some handling issues that were improved with bottom changes/updates. As I understand it even with the updates the F34 has some inherent handling issues. There are a few F34 owners that have spent a lot of money on setup to get the boat to work and I would try to get in contact with those owners to learn from their experiances. I saw a video on the DCB section here of a member that looked like he got the setup pretty dialed in.
Dave or Tony at DCB may have some thoughts on an Arnesons that may or may not help you in the decision making process.
Don Johnson is offline
Old 10-22-2015 | 09:42 AM
JDB1981's Avatar
It does have a mini pod I did read in the dcb section about the one guy got his set up with no bottom work but he raised the drive
JDB1981 is offline
Old 10-22-2015 | 10:20 AM
Skidoc?
JRider is offline
Old 10-22-2015 | 12:15 PM
Rik's Avatar
Rik
Less than half the weight
Rik is offline
