the first surface drive cat w/ bustle >
Old 11-19-2015 | 02:41 PM
Default the first surface drive cat w/ bustle
http://www.portcarlingboats.com/2014/09/
https://www.google.com/search?q=1917...utf-8&oe=utf-8
also i have left over part# 25-54521 big o-ring and spring clip still in bag.
used on the trs tailstock so i guess
it'd work if you have conrads as well.
pm me your address gladly send it off to you
dan
outonsafari is offline
Old 11-19-2015 | 03:19 PM
Also owner "pull it in style" MYCO
SkaterMike82 is offline
Old 11-19-2015 | 03:22 PM
Spinning out..that boat will never break 100mph.
Cole2534 is offline
Old 11-19-2015 | 03:44 PM
tryin to figure out that rudder system? dang . How does that work?
klaatutooyou is offline
Old 11-19-2015 | 05:08 PM
Looks like the pinion gear moves the shaft below it....the shaft pushes the rudder out...when the wheel is returned to center, the spring above, retracts the rudder back to the retracted ( straight ahead)position.
It's borderline on a Rube Goldberg type of a device
JaayTeee is offline
Old 11-19-2015 | 05:09 PM
I think it works on opposing rams of sort activated by the rack on the center of the transom. Port turn - port rudder pushes out on the trailing edge and the stb. rudder stays straight like a turn fin.
The bronze age - ding a prop - just hammer it out so it looks good and go- LOL
speicher lane is offline
Old 11-19-2015 | 06:48 PM
Thanks for sharing..
Curiously I found this video. Yes I was hoping for a surface piercing rooster in 1917..
https://www.youtube.com/watch?v=EnM86owl2Wc
cmattj is offline
Old 11-20-2015 | 07:15 AM
I think you got it nailed. Looks like that linkage can also pick up a rudder maybe.
Cole2534 is offline
Old 11-20-2015 | 08:32 AM
Always been a fan of Hickman sea sleds .
I think that rudder system is where the rumor originated that surface drives are hard to maneuver around the dock.
tommymonza is offline
Old 11-20-2015 | 09:03 AM
Comanche3Six's Avatar
Gar Wood invented the dump truck too, quite the genius.
Comanche3Six is offline
