How important is engine synchronization? >
Old 01-15-2016 | 09:34 AM
phughes69's Avatar
Default How important is engine synchronization?
How many rpm difference is acceptable between two engines when they are running at any speed from cruise up to WOT. With modern fuel injection I know it is possible to have the engines synchronized to each other very closely if the throttle bodies are fly by wire, but what about EFI engines that still have a cable operated throttle body. Does Mercury or any other manufacturer automatically sync their engines above a certain rpm?
phughes69 is offline
Old 01-15-2016 | 09:40 AM
It's kinda of important for stress relief. You may have to adjust/replace throttle cables but once you get it is a sound. The sound is more telling than any tach. There is a harmony there and you will know. Even if sticks ain't perfect.
Crude Intentions is offline
Old 01-15-2016 | 09:48 AM
F-2 Speedy's Avatar
And what a sweet sound it is...............
F-2 Speedy is offline
Old 01-15-2016 | 10:22 AM
I have the tachs and a syncro gauge.....but it's the sound!!!! You'll know it!!!!
On the remodel the Syncro gauge is leaving the panel. Unnecessary space!
CDShack is offline
Old 01-15-2016 | 10:30 AM
^^^ Yes indeed..
With drive trim.. cable adjust... prop variance and even boat lean that can effect engine twin synch. I always eyeball the tach for a quick look as i twist the sticks to harmonize it .
My buddies Cruiser yacht has a actual synchronizer that runs off the coils. Haven't got a grip on that one.
cmattj is offline
Old 01-15-2016 | 11:03 AM
How sweet that sound is.
twinscrews is offline
