need help with Sea strainer installation?
Install ball valves and bypass. Had a lid break in half during a poker run and would have sunk if I would not been able to shut off and keep motors running while pumping out water.
Very important. Since you will need some elbows or 45 deg. bend fittings, make sure they are the type that have a larger radius bends and true 1" or 1 1/4" INSIDE flow. many fittings may have the right threads but smaller diameter on the inside. It will restrict your flow. (I have some extras. )
