Removing oil filter w/out a mess ????? >
Old 03-18-2016 | 12:53 PM
Originally Posted by Too Stroked
This whole thread has been about the remote filter on the 496 Mag. Mercury uses them on most motors now because they're so much less of a pain than the OEM filter location.
DOH! I missed that part! My experience was with the 500 EFI (blue motors) so that's what I was thinking of! My bad.....
Gary P is offline
Old 03-18-2016 | 10:31 PM
I ram a screw driver thru the filter, relieves some stress at the same time.
ICDEDPPL is offline
Old 03-19-2016 | 08:05 AM
Originally Posted by Knot 4 Me
I've never poked a hole in an inverted filter. Break the seal, let it drain a bit, unscrew a tad more and lift, let it drain, etc. Be patient and it will drain back into the remote filter pad and you can remove it without spilling a drop. Usually takes just a few minutes for it to fully drain so you can remove it. If you get in a big hurry or unscrew it too far too soon then you will have a mess on your hands. I usually sit with a beer after I crack it open and occasionally lift up on the filter to ensure it is draining.
This approach works fine. Have never spilled a drop doing it this way.
Ryan00TJ is offline
Old 03-19-2016 | 08:27 AM
90profx is offline
Old 03-19-2016 | 01:24 PM
Little Tommy's Avatar
plastic bag works great rap around it
Little Tommy is offline
