Tie Bar help
Old 03-26-2016 | 07:17 PM
Default Tie Bar help
I have two TRS drives out the back of my old cigarette and the join on one outdrive where the rod connects vertically to the top of the drive with the circular bolt connection has sheared off from metal fatigue/corrosion
is this part easy to replace can anyone help me??
also you see some boats modified with multiple tie rods and bars is the extra ridgitiy really worth it should I consider this?
thanks
way2fast is offline
Old 03-26-2016 | 07:26 PM
are you talking about the heim joint that threads into the tie bar
http://www.speedwaymotors.com/FK-Rod...int,81634.html
http://www.speedwaymotors.com/FK-Rod...int,73676.html
there's probably a better place to get them, these were the first ones that came up on google
outonsafari is offline
Old 03-30-2016 | 01:38 AM
I see no need for multiple tie bars....
iliveonanisland is offline
