Next Goodwin-Powered Platinum Edition Skater is in the Works
#41
Could you please post a pic of the Orange when you get it? My boat is mostly a deep orange as well, would like to see how close it is.
#42
If someone can build big HP motors (1100 hp +) and get 250-300 hours out of them I'm on board regardless of valve train. Problem is not many have. Mercury isn't perfect but have accomplished this on a consistent basis. I do however that Bill P's 388 might be the best sounding machine ever.
#43
#44
Spoke to seadek yesterday and they are having issues with the color on the red and orange still but hope to have it worked out soon. I plan on sticking a sample on the roof of my truck for a little while and seeing how it hold up.
#45
The Seadek material holds up well with some consideration for wear and tear - If you abuse the hell out of it - it will show... Simply like everything else!
If you have any marina's around that are dealing in Used Ski/tow boats ( Correct Craft for example) they will 99% likely have Seadek installed... Biggest issues we had with the Nautique was not enough care on install (not fully cleaned/De-greased) and a edge would lift.
Generally the colors were fast but Red may be prone to discoloring premature... only a few boats we had had a red underlay (under tan or Grey surface).
#46
If the SeaDek gets installed over non-slip/textured surfaces whats to keep the water from being trapped between the foam and deck? Seems like trapped water would get funky after sitting for a while.
#47
I can however attest to many people who in stalled it years ago over their original surface and there is no funk, smell, or anything like that at all.
#48
#49
I have only seen the flooring installed over a diamond pattern non-skid and one very flat stipplied non skid... the backing adheisive is like a graphic (peel barrier and apply in one shot). If you get it down solid and the edges are tight to the floor- water does not pass under it as it takes a bit of work to get the panels off later
