Problems with Arneson 7M Surface Drives
#42
#7M DRIVE UNIT RIGHT HAND ROTATION LEFT HAND ROTATION
Reduction/Overdrive 1:1 1:1
1.32:1 1.32:1
1.56: 1.56:1
Transmission Velvet Drive
Kit Unit Weight 320 lbs
OAL 52”
Steering Angle 40 Degrees
Trim Angle 17 Degrees
Maximum Input Torque 850 lbs 850 lbs
from arneson ... maybe 1100 hp is too much??
1.32:1 1.32:1
1.56: 1.56:1
OAL 52”
#46
1.32:1 1.32:1
1.56: 1.56:1
OAL 52”
1.32:1 1.32:1
1.56: 1.56:1
OAL 52”
#47
Oh snap.... that really sucks i can so feel for you bro....
#48
I can't speak to the personal issues he is having with Ric but I have known since the day I put 7M's on my boat that they were a much stronger alternative to XR's - but they are not an alternative to Six drives. It's pretty common knowledge in the Arneson world that if you have 1100 HP mills that you should be running ASD 8's - not 7m's.
Now, the #8 says 1200hp for max rating. I thought I saw where his motors where dyno'd to 1205hp or something like that.
Edit in: Post #38 in link below. This was in 2013 so not sure if motors have been changed or detuned or something.
http://www.offshoreonly.com/forums/s...ml#post3940007
Last edited by SB; 05-10-2016 at 12:52 PM. Reason: Chart says 1200, I had typed 1100hp
