-   -   Char lynn helm ID, cant find info. (https://www.offshoreonly.com/forums/general-boating-discussion/337567-char-lynn-helm-id-cant-find-info.html)
phragle 05-21-2016 11:30 AM
2 Attachment(s)
Ive googled and googled... CAnt find this part number anywhere and trying to figure out what size it is.
211-1098-001
[ATTACH=CONFIG]555791[/ATTACH]
[ATTACH=CONFIG]555792[/ATTACH]
c_deezy 05-21-2016 12:10 PM
Overall pictures would help...
phragle 05-21-2016 12:14 PM
1 Attachment(s)
[ATTACH=CONFIG]555793[/ATTACH]
F1-00 Racing 05-21-2016 12:38 PM
so far all I can find with a quick search is that yours was made the first week of January 2002... maybe you can call Eaton and they can help
JMPH 05-21-2016 01:33 PM
Completely of topic but when you install a helm does the fittings go straight up?
14 apache 05-21-2016 01:40 PM
Measure how thick the rear spacer is under the cover and go on this and you should be able to figure out the displacement.[PDF]110, 230, and 450 Series - Eaton
This is not a link but copy and past to search it.
vintage chromoly 05-21-2016 01:48 PM
You can index the helm in any direction. It's pressure fed.
phragle 05-21-2016 04:16 PM
Best I can figure out is that its a 95cc. withn a small dual ram system is that faster or slower??
14 apache 05-21-2016 04:36 PM
Probably around 3 turns lock to lock. Ball park.
Wobble 05-21-2016 04:55 PM
http://www.vickershydraulics.ru/page...pdf/11-872.pdf
spec sheet from 2002, might help
