We need an Outboard section in Technical >
Old 08-15-2016 | 10:25 AM
  #71
Dave M's Avatar
Veteran: Navy
Originally Posted by bulletbob
S&F. The best for outboard info. Bar none.
They don't seem to want to talk about 4 strokes over there too much.
Dave M is offline
Old 08-15-2016 | 11:24 AM
  #72
Well I've boated with two stroke power for 4 decades and went to the dark side briefly and came back to OB power now Verado Power. I have no desire to do inboards again.
I haven't used the new Verados enough yet to give a full opinion yet. The DTS is incredible and they are so quite and user friendly around docks. At WOT you can talk normally and hear behind my windshield. I feel the 400Rs will prove to be a great compromise between both IO and two strokes.
There are so many set up variables and modifications which easily cross all makes and hull types of OB boats. S and F is good but typically I have found geared more towards two stroke and smaller hulls. I think and Outboard section would be very valuable.
I don't miss watching and adding two stroke oil to resivoirs but I do miss the smell of burnt two stroke oil in the mornings. It smells like victory.......
skate is offline
Old 08-15-2016 | 11:56 AM
  #73
Hey! Hey what's wrong with a little smoke and oil once in while!!!!!!
Something to be said about the sound of the real racing 2 strokes..... Music to my ears....
https://youtu.be/I2HkOvzckVs
Double Rigged is offline
Old 08-15-2016 | 01:00 PM
  #74
Did you miss my last sentence???
skate is offline
Old 08-15-2016 | 10:15 PM
  #75
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
I just crossed over to the dark side. Yammie F300 on my.........wait for it........25' pontoon boat! Funny thing is that's it's the most expensive boat I've ever owned!
Baja_342 is offline
Old 08-16-2016 | 11:30 AM
  #76
bck's Avatar
bck
Charter Member#568
If all the big block I/O guys detuned their engines to OB power levels they would probably have the same reliability. Start with an 800 hp blown 540 and keep removing parts and lower cubes till it's down to about 300 or so hp.
Straight bottoms and flat decks
bck is offline
Old 08-16-2016 | 12:04 PM
  #77
Maybe. But that 300hp I/O package will be slower than the 300hp OB package.
6.2L 300hp- 862lbs + Alpha- 85lbs = 947lbs
300XS (XL-25") = 517lbs
Speedracer29 is offline
Old 08-16-2016 | 12:42 PM
  #78
Not to mention a 6.2 L produces 0.79 hp/cid
And 3.2 L OB 1.53 hp/cid
1350 Merc 2.45 hp/cid
400R 2.6 hp / cid
skate is offline
Old 08-16-2016 | 02:53 PM
  #79
2 Trick Rick's Avatar
Racer
They have one... OffshoreOnly.com/OutBoard
2 Trick Rick is offline
Old 08-16-2016 | 03:01 PM
  #80
You would also probably have to have a shorty with a extension box to get the same CG and prop height as an OB.
Pete280 is offline
