Need a machinist
Old 09-07-2016 | 06:27 PM
I have a local general machinist in Severn that can make anything you could think of. I'll send you a pm with a name and number. He is extremely well versed in power transmission components.
mickeymcclgn is offline
Old 09-07-2016 | 06:54 PM
if they are stainless they would have to be custom I would think, the ones in my Casale V-drive are both steel.
compedgemarine is offline
Old 09-07-2016 | 10:49 PM
Hey mxz, being it spins up to 5000 rpms tolerances are pretty tight. The only thing I can find out from Casale of what they are made from is “Aircraft alloy steels” which who knows what it is being they use that line in every advertisement. I now don’t think they are stainless steel being they are magnatic.
Micky, I will call him tomorrow. I live in Pasadena, Severn is around the corner.
Comp, I think you are right.
I finished taking them apart and did some real measurements. They are even simpler than I thought.
f_inscreenname is offline
Old 09-08-2016 | 07:16 AM
mxz
Actually those tolerances are not tight at all.... lol..... I don't see why they would need to be ground. Also there is magnetic stainless but it is doubtful that they are.
mxz is offline
Old 09-08-2016 | 09:02 AM
f_in, I'm helping a friend repower a boat and will most likely use Casale v-drives. Could I pick your brain sometime about the drives and the company? I don't have much experience with them. I'm local...Annapolis area.
BradH is offline
Old 09-08-2016 | 11:52 AM
Mbam's Avatar
Offshoreonly Advertiser
I think you are better off making new ones. A pre-hard 4340 would be a good material. You really need to determine the ID of the gears and spec for a press fit. Then look up the bearing specs and get a recommended fit also.
http://www.amesweb.info/FitTolerance...eImperial.aspx
If you get stuck I have a local guy here in FL that can do it. We have the equipment but not the time
Mbam is offline
Old 09-09-2016 | 12:24 AM
Thanks folks for the help. Took them to a local guy. He seemed to know all the same people that I trusted in the area and came across as knowing what he is doing. Making new. Have my fingers crossed.
Old 09-09-2016 | 12:37 AM
fingers crossed...
Ghost24 is offline
Old 09-12-2016 | 11:19 AM
Mickeymcclgn’s guy (Robert) kicked ass.
Two day turn around, great guy, listens, gives great feedback, extremely cheap, does great work… You need a machinist in Maryland get ahold of Mickey or me and we will pass his info along.
Old 09-12-2016 | 11:31 AM
Those look well done, if you don't mind me asking what did it cost to get done?
turbom700 is offline
