What are the chances I can find my prop? >
Old 11-21-2016 | 07:02 AM
  #81
Keep in mind when the prop shaft and prop come off it will still corkscrew in the water. So it may be outside your radius
Drew555 is offline
Old 11-21-2016 | 10:05 AM
  #82
Yep
Tried to sneak across the bar in a real shallow ever changing Pass I had to go through all the time.
12 feet of 1-3/4 shaft and a 30 inch prop went out the bottom of the boat when it bumped hard at 20 knots.
3 feet of water and I could not find it where I bumped. It had spiraled a 100 feet off to the side of the impact.
tommymonza is offline
Old 11-21-2016 | 04:12 PM
  #83
Damn that`s a good point.. never thought about that
ICDEDPPL is offline
Old 11-21-2016 | 05:30 PM
  #84
rak rua's Avatar
Originally Posted by BigSilverCat
They stop spinning almost instantly, probably only made one or two revolution and probably a flip. Not much mass for the resistance of the water.
I'm sure Big Silver Cat knows a lot more than me but I agree with this. ^^^^^
The prop on it's own, without a drive and boat to guide it, has no balance and little traction on the water, it's not like a wheel coming off a car and bouncing down the road, a prop will flip over, twist, turn, spin and sink. I can't imagine it would continue to run a course in any one direction.
If the water was very shallow and it hit the bottom spinning, it may have 'run' along the bottom a little but at idle speed, I doubt she'd have gone far.
RR
rak rua is offline
Old 11-21-2016 | 06:25 PM
  #85
interesting dilemma as to where the prop goes , my 2cents I have broken some bolts that hold the blades on my zero turn mower , as fast as lawn mower blades spin you would think it would fly or at least bounce around . they fall straight down , I can always find the bolt and washer and broken blade just under the deck I would think the prop at idle or slightly above would just drop .
waycool marine is offline
Old 11-21-2016 | 08:05 PM
  #86
Keep in mind.... i think he just shifted to reverse at idle and it fell off
mcprodesign is offline
Old 11-21-2016 | 09:58 PM
  #87
TENSION's Avatar
got me thinkin about just whats out there, hell i might get one of these just to have on board, Cheap handy thing to have around . . . . .
http://www.ebay.com/itm/ATLANTIS-UND...0AAOSw4shX-roI
http://www.ebay.com/itm/EYOYO-7-Moni...3D152300960479
Hmmmmmmm..........reading the review about the Atlantis camera.....!!!!
TENSION is offline
Old 11-21-2016 | 10:02 PM
  #88
I have to agree , unless it came off earlier than he thinks , at idle speed it should not have traveled very far.
spinning in or out, direction of travel for boat , mark out a vector search, and widen .
if the search is off for the season it may be hard to find come springtime due to settling , sediments etc.
buck35 is offline
Old 11-24-2016 | 08:40 PM
  #89
phughes69's Avatar
Any update on the search for the missing prop?
phughes69 is offline
Old 11-26-2016 | 08:24 PM
  #90
So it looks like a day of decent weather.
My version of a prop catcher complete with $270 worth of neo magnets , fish camera and go pro... I`m going to drag that thing behind a jet ski and see what I can "catch"
Expecting major shrinkage tomorrow
ICDEDPPL is offline
