388 Hustler Slingshots
Old 12-06-2016 | 11:34 AM
  #91
Phil is our safety barometer. Oh god
Bravos blow. We all get it. The only other reason I would say a normal drive might be safer other than a cavitation plate is with normal drive anyone near the drive can gauge how close they are to the prop. With ASD's only being shafts there is no height and nothing protruding from the water. Almost like an anchor. nothing to really gauge where the prop is...I guess the solution is to raise it above the water.
1MOSES1 is offline
Old 12-06-2016 | 11:42 AM
  #92
bck's Avatar
bck
Charter Member#568
Originally Posted by Nate5.0
genius.
maybe I will start just grappling my way up the side of the boat or the nose when I am in the ocean taking a swim, I mean it seems completely easy to do.....never even knew why I ever used the swim platform and the back of the boat to begin with.
got to have priorities
Straight bottoms and flat decks
bck is offline
Old 12-06-2016 | 12:16 PM
  #93
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
I don't know if you realized I've made the prop guards for these since like 2003 and this eliminates this exact issue and covers far more of the propeller than a cav plate on a Bravo does.
Arneson Surface Drives www.arneson-industries.com
Rik is offline
Old 12-06-2016 | 12:28 PM
  #94
Dean Ferry's Avatar
Veteran: Air Force
Originally Posted by rik
i don't know if you realized i've made the prop guards for these since like 2003 and this eliminates this exact issue and covers far more of the propeller than a cav plate on a bravo does.
bingo!
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 12-06-2016 | 01:40 PM
  #95
[ATTACH=CONFIG]562471[/ATTACH]
[ATTACH=CONFIG]562472[/ATTACH]
It's a big difference, seems much more than 4". And height as well. Again, just me I guess...
Attached Thumbnails 388 Hustler Slingshots-img_7689.jpg   388 Hustler Slingshots-img_7688.jpg
Eliminated572 is offline
Old 12-06-2016 | 01:48 PM
  #96
I picked up on that earlier in the thread. Still doesn't address the fact that arnesons are essentially buried in the water like an anchor. At least with bravos the top cap is exposed at all times even when not trimmed up. This at least offers some guidance as to where the prop is...with the arneson it might as well be a rock on the bottom of the ocean.
Not even sure why people are arguing the fact that the risk level is higher with a fully submerged prop that hangs further off the back of the boat. let's argue for the sake of arguing.
1MOSES1 is offline
Old 12-06-2016 | 01:58 PM
  #97
bck's Avatar
bck
Charter Member#568
You could get one of these add on platforms. You could then run any drives you wanted without losing an eye and be able to pitch a tent on the back. Win, win
bck is offline
Old 12-06-2016 | 02:12 PM
  #98
Too be fair you should have had the pictures at the same angle or straight down transom
green lightning is offline
Old 12-06-2016 | 03:42 PM
  #99
Google images.... I tried
Old 12-06-2016 | 03:46 PM
  #100
[ATTACH=CONFIG]562476[/ATTACH][ATTACH=CONFIG]562477[/ATTACH]
Not a bad idea bck
Attached Thumbnails 388 Hustler Slingshots-hustler-swim-platform.jpg   388 Hustler Slingshots-hustler-swim-platform2.jpg
