Best old 23ft offshore boat for $10-12k? >
Old 12-05-2016 | 09:56 AM
Originally Posted by Padraig
Excellent fast boat. The bottom is the same as a Velocity 22. However it is a little heavier and the cabin, for a 22/23 ft go fast, is not bad. My wife and I used to overnight in ours. A 1989 with 454 mag comes with full hydraulic steering and a Bravo drive. Pachangas have an alpha drive. On a good day with a light load and some good chop mine would just hit 71/72 mph.
Padraig
Do you know anything about the construction? Balsa wood core or solid glass?
72ndPoolShark is offline
KN
How about a 23' Warlock if you can find one.
KN is offline
Old 12-05-2016 | 10:01 AM
Not seeing a cuddy in the one's I see on boat trader
http://www.boattrader.com/listing/19...K-23-102356522
Old 12-05-2016 | 10:06 AM
A little over budget but looks to fill the bill.
https://orangecounty.craigslist.org/boa/5811284924.html
GLENAMY 242SS is offline
Old 12-05-2016 | 10:11 AM
http://www.powerboatlistings.com/view/32177
beautiful lines
vote for this one
css19 is offline
Old 12-05-2016 | 10:17 AM
beautiful lines
vote for this one
The Pachangas certainly are beautiful boats, but 330hp with an alpha outdrive...
Old 12-05-2016 | 10:19 AM
But doesn't have a cuddy. Looking for a stock 454 bravo, not a mercury racer. Want ultimate reliability.
Old 12-05-2016 | 10:46 AM
Going by memory but pretty sure it is end grain balsa like my 280 was. Whether balsa or not, whatever you get serious about you need the check for moisture. Balsa if built correctly should not be a problem. Even without Balsa you still have transom and stringers to worry about. You are looking at older boats so check all carefully.
Padraig
Padraig is offline
Old 12-05-2016 | 10:51 AM
Also, blckkat said the Pachanga limit is 3ft. Understandably many boats won't like over 3's. Anyone say their choice will run larger than 3 footers reasonably well?
Again, I'm looking for stock 454 bravo, 23ft-ish cuddy. Top speed is unimportant to me. Fuel use is important to me for 25-35mph long range cruising.
Old 12-05-2016 | 10:54 AM
Going by memory but pretty sure it is end grain balsa like my 280 was. Whether balsamic or not, whatever you get serious about you need the check for moisture. Balsa if built correctly should not be a problem. Even without Balsa you still have transom and stringers to worry about.
Padraig
True and I will be getting pro survey, rack storing, but would still prefer to avoid as much wood as possible.
