Originally Posted by VoodooRob
(Post 4523184)
Received 2 sheets of stainless from Discount Steel yesterday. They were wrapped and sandwiched with particle board and then wrapped in cardboard. Shipped thru Fed ex ground no damage. This picture is the back of the stainless so ignore the light scratches, the front is covered with a mask to protect it. I also ordered a 100' roll of 1" Ultra High Bond 3M double sided tape, you have seen it as emblem adhesive in the auto parts stores. Will update once everything is received.
[ATTACH=CONFIG]564146[/ATTACH] Looks good. Did you have them notch a hole for the ram mount or are you going to make that cut? |
1 Attachment(s)
Originally Posted by I.C.U.Lookin
(Post 4523312)
[ATTACH=CONFIG]564156[/ATTACH] |
3 Attachment(s)
Using 3M VHB double sided 1" wide tape, 100' roll so i'll have some left over. Also ordered adhesive promoter pads from 3M, they smell like rubbing alcohol but leave a slightly tacky surface. I feel it is very important to get as much of the oils/debris as possible off the backing of the stainless panels. Clean surface = stainless that sticks and stays put. Set the tape aprox 6" apart, thanks to Neil "HyFive578" for the tip. I installed port side, starboard side I had to template for the fender holder. There is no fun house, wavy look and that is a relief. The 18 gauge stainless is about as thin as I would go to avoid the issue. Will post final photos and total cost for the project once vinyl decals arrive this week.
[ATTACH=CONFIG]564462[/ATTACH][ATTACH=CONFIG]564463[/ATTACH][ATTACH=CONFIG]564464[/ATTACH] Sorry for sideways pics, posting from my phone |
Looks nice!
Looks great Rob. That's exactly how I applied the VHB tape. That is NEVER coming off...
Originally Posted by HyFive578
(Post 4526404)
(Post 4526407)
Once the tape made contact with the 3M promoter there was no coming back and re-aligning. I agree with you, at first I was 50/50 about adding some set screws and washers for "just in case", definitely no need after feeling the bond.
(Post 4523368)
Not necessary on my boat, rams mounts are not close in the area, makes this very easy to do. Only thing I have to template is the fender mount on the starboard hatch. And yes I am fixing the rubber gasket that is coming off the hatch too!
Originally Posted by 1989mach1
(Post 4526599)
Wow I wouldn't know what to do with all that room
5 Attachment(s)
Total cost for project: 2 Custom cut stainless sheets, 100' 3M VHB Tape, 2 Custom logos $380 all in. Starboard graphic is smaller to allow for fender holders.
[ATTACH=CONFIG]564679[/ATTACH][ATTACH=CONFIG]564680[/ATTACH] While I was at it, had some deck and misc vinyl graphics made [ATTACH=CONFIG]564681[/ATTACH][ATTACH=CONFIG]564682[/ATTACH][ATTACH=CONFIG]564683[/ATTACH] |
What made you decide to go with the SS over acrylic?
Looks Great!!
Originally Posted by IGetWet
(Post 4528161)
Nice steering wheel. Looks good.
Nice work, looks like windshield is getting updated as well. These are the projects that make winter season pass by quickly.
I see discount steel has 20ga and 22ga. Is there a reason you went with the 18ga / would the 20 or 22 bend or warp when mounting?
(Post 4528736)
Originally Posted by Kelly O
(Post 4528682)
Originally Posted by MAXIMUSXXX
(Post 4528464)
Got it, exactly what I was looking for. Thanks for the help. I'll be ordering from discount steel as well.
Looks awesome Rob! Excellent workmanship. I may have to copy what you did there.
(Post 4528745)
Thanks Kelly, you've seen the movie. I'll start another thread about that. Windshield surround is going from white to purple and anything that was original purple is getting re-done because everything was flaking, the windshield hardware looked terrible.
Many people have contacted me for more info since this thread went up, I want to thank everyone that has contributed so far. Anyone else out there want to post pics, suppliers, etc?
8 Attachment(s)
I did acrylic. Bought locally at Johnson Plastics. I used the 3M VHB tape. Install was pretty straight forward. It's good enough - the hatches don't raise up enough to see in from the dock anyway.
Looks excellent Terry!
I went with discount steel as well. Haven't hung them up yet but I think it'll look killer. When you guys taped them up did you use anything to hold or press them on the hatch firmly for a while to let the tape set up and stick good? Rob what about cleaning or polishing the SS? I'm afraid just taking a terry or microfiber cloth will scuff the polish. Do you use anything in particular?
And how are you guys posting pictures? I can't from my phone or from Photobucket anymore |
For the tape, wipe down the attachment area with the 3M accelerator wipes, also rubbing alcohol would work. Warm the hatch and the tape with a heat gun, and apply. The tape will stick very well, you get one shot at it, no peeling and resticking.
For cleaning fresh micro fiber towels and any stainless specific cleaner or polish. I like blue magic stainless steel polish. And yes posting pics now sucks on this site. |
I always liked what Sunsation does with their underside engine hatches. the 36 and the 43. And their installed custom trim pieces
Originally Posted by BUP
(Post 4572179)
2 Attachment(s)
Photos
https://cimg2.ibsrv.net/gimg/www.off...68257e61d7.jpg
https://cimg9.ibsrv.net/gimg/www.off...bd596f6f70.jpg Good info.,,,I looked at the stainless when i did mine it was real bad expensive. I did mine in the acrylic mirror, On my hatch its not flat, I used the bolts that hold the hatch sun pad. and some 3m tape, in the middle. Not using the hatch cover bolts I would of had to protect the back side of the mirror from them and it would of made the mirror distorted, One thing about the acrylic the silver on the back that makes it a mirror will rub off, silver deteriorates on the edges , like a old mirror in your home bathroom, I was going to cover the back side of the mirror w/ vinyl to help with the wearing off of the silver but after cracking 3 of them,didn't want keep throwing $ at it, Also I was having to buy hole sheets to do just one mirror,7ft long, over 2 ft wide, I ended up keeping all the drops since he was charge me for the hole sheet any way, and used them in on the sides and other places. I think I was paying around 140 for a sheet plus some labor cutting it, For the bolt holes I made them bigger and put a rubber sleeve over the bolt to keep it from touch the mirror and cracking it, also I did the counter sunk washer and made some teflon washers so the chrome washer would not touch the glass,being these bolt were hold the hatch cove on it was easy to over tighten them and crack the mirror. It looked great for a while until it cracked at some of the bolt on places, I made a cover for my ac on my Chevelle and it help up great and still like a mirror, I did a pc to cover my firewall behind the engine and its seen some wear,but both prob 20+ years old, Not sure what grade/# of stainless it was, had a sheetmetal buddy that did the hole front of a office building and had some left over pc's Thanks for the info above on the Stainless, I try it next time for sure. Rob |
See a piece of dust down at the bottom right corner....might wanna take care of that Rob.
Originally Posted by Open72
(Post 4621663)
yea yea, hey get finished with that boat and paint my Chevelle |
(Post 4528157)
[ATTACH=CONFIG]564679[/ATTACH][ATTACH=CONFIG]564680[/ATTACH] While I was at it, had some deck and misc vinyl graphics made [ATTACH=CONFIG]564681[/ATTACH][ATTACH=CONFIG]564682[/ATTACH][ATTACH=CONFIG]564683[/ATTACH] Asking ----- thats graphics (FOUNTAIN) on the mirror ? and the 3 m VHB tape to hole it in place against the bottom of the hatch ? What prep work did you do for the bottom side of the hatch ? Im sure first was making sure it was completely level all way across so the 3 m tape would stick at all points. Thanks and very nice as well. |
Originally Posted by Strip Poker 388
(Post 4621658)
(Post 4621678)
Just checking
Asking ----- thats graphics (FOUNTAIN) on the mirror ? and the 3 m VHB tape to hole it in place against the bottom of the hatch ? What prep work did you do for the bottom side of the hatch ? I'm sure first was making sure it was completely level all way across so the 3 m tape would stick at all points. Thanks and very nice as well. |
Mirrored Stainless
https://cimg2.ibsrv.net/gimg/www.off...c452d3782.jpeg The only way to go, stainless steel afixed with 3m 4200. |
(Post 4621699)
Graphics are 3M Vinyl. The vinyl is transparent silver so it looks like the logo is etched on the stainless. I prepped the hatch surface and stainless mounting side first by stripping any cleaners, oils with de-natured alcohol. Then I used 3M accelerator pads, that are designed specific for bonding the 3M tape to the surfaces, to leave a layer of accelerant on both surfaces. Let it all tack up and assemble.There is some give in the 3M tape so the surface being bonded to does not have to be perfectly level.
(Post 4526652)
I will never own a side by side setup again. Staggered really makes maintenance and cleaning a breeze.
| All times are GMT -5. The time now is 04:09 AM. |
