Center of gravity
Old 02-12-2017 | 08:12 PM
  #31
SB
Originally Posted by TYPHOON
I get that part. So are we debating the term center of gravity and it should be center of balance LOL. I only know it as CG in the boating world but doesn't mean it right.
Center of Gravity (ie: center of mass) is typically the balance point, but not always depending on shape. How can you balance a ring of any size horizontally? LOL.
Here's a good read, that's easy to read, I found:
http://dev.physicslab.org/Document.a...CenterMass.xml
SB is offline
Old 02-12-2017 | 08:31 PM
  #32
Full Force's Avatar
I have been in 311 Formula with TRS, and also Bravo, they ride totally different same speeds and options, so there has to be a difference in COG there, seems the Bravo boats porpoise more, same as Cig Café TRS/bravo..
Full Force is offline
Old 02-12-2017 | 08:55 PM
  #33
Originally Posted by madbouyz
No it's not. It's center of balance . Ever done airline operations ? It's 'weight and balance' .
Like a 62 ton Abrams tank in a C5A ?
Interceptor is offline
Old 02-12-2017 | 09:04 PM
  #34
Well I gess that explains why my boat lost 10mph after I added a 19in flat screen TV in the cabin......
1989mach1 is offline
Old 02-12-2017 | 09:05 PM
  #35
I must have mounted it to far forward
Old 02-13-2017 | 07:10 AM
  #36
The trs is deeper in the water!
shaun harrington is offline
Old 02-13-2017 | 07:33 AM
  #37
I've been in all of those, someone you were with couldn't run a boat too well. the only cafes that porpoise uncontrollably were the few that got a notched transom, that was more to do with drive height than style of drive
Unlimited jd is offline
Old 02-13-2017 | 08:08 AM
  #38
Full Force's Avatar
I was told they are same depth as Trs...
Old 02-13-2017 | 08:09 AM
  #39
Full Force's Avatar
Oh itnwas not out of control at all, just seemed the Trs boats rode more solid...both can run boats fine justbdifferent ride
Old 02-13-2017 | 08:10 AM
  #40
I'm pretty sure the trs is longer, not sure if the x-dimension was altered to compensate.
