Your Thoughts on Aluminum Engine Blocks ?? >
Old 07-21-2017 | 09:36 PM
Ceramic coating all passages and combustion areas of heads run 2k per motor.
class6 is offline
Old 07-22-2017 | 09:21 AM
Ironmanwb's Avatar
Innovation marine and Donovan had a joint venture where they made all aluminum engines for the us navy. The reilabily/durability testing they had to do to get the contract was pretty extensive 300+ hrs non stop at wot . I have a pair of them in my boat. I have not personally run them enough yet but i hope they last at least that long.
http://
http://
Ironmanwb is offline
Old 07-22-2017 | 03:57 PM
I think this is enough information, It seems like the aluminum blocks will work for offshore use.If mercury can use it then it is good enough for me.
why would the passages be damaged if you always rinse the motor after taking the boat out of the water,I am talking about run it and then take it out in some hours and flush it with fresh water...?
turbos230 is offline
Old 07-22-2017 | 04:37 PM
F-2 Speedy's Avatar
Im pretty sure the Hawk engines back in the day were aluminum tall deck Donovan's
F-2 Speedy is online now
Old 07-22-2017 | 06:45 PM
You running in salt water?
indysupra is offline
Old 07-23-2017 | 09:17 AM
Every modern day outboard is all aluminum even the 7 marine that is corvette motor with a blower. I would see no issue
risco is offline
Old 07-23-2017 | 09:27 AM
SB
Bare aluminum ? If not, what coating or process ?
SB is offline
Old 07-23-2017 | 10:46 AM
B38
Closed cooling is the only way. My 2 cents 😀
B38 is offline
Old 07-24-2017 | 11:34 AM
Yes running in salt water
But I remembered now one time I found a beer can on the beach in the water all aluminum and it was damaged -but there was no corrosion or anything wrong with it from the saltwater,I dont know how long it was there but what is the real problem with saltwater and aluminum? I am also saying to use the boat for some hours and then rinse the engine well with fresh water
Old 07-24-2017 | 12:44 PM
SB
A beer can in water does not have any steel, stainless steel, and etc bolted to it nor pressed into it.
Search and study electrolysis. I see issues in fresh water with people who do not address it.
Also, I believe Corey331 ran into issues this past year with his aluminum LS motor. Engine is just 1 or 2 yrs old.
SB is offline
